Old 07-19-2005, 01:23 PM   #1
halffast blazer
halffast blazer's Avatar
whats the difference between frames?
on '73-'87 k5 blazers, what is the difference 2wd VS 4wd frames? will 2wd suspension bolt on to 4wd frame, and vise versa?
halffast blazer is offline   Reply With Quote
Old 07-19-2005, 03:31 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The actual frame rails are the same, everything else is different. Leaf perches in the back are longer (makes it taller), tranny/t-case crossmember is different, brake mouting holes are in a different location, engine crossmember is different....
I am assuming you are asking this because you are wanting to convert. While the search is up, might want to look for 2wd conversion or something like that. This has been discussed A WHOLE LOT!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-19-2005, 05:47 PM   #3
Jonboy
Slots go on anything!
There are some minor body mounting differences also when they went to the dropped floor in 78. A couple of the rear floor mounting points are different, although I can't remember which ones they are right off hand.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 07-19-2005, 07:08 PM   #4
halffast blazer
i should have said i have parts from an 82 2wd and i might buy an 81 4wd. so i may switch suspensions.
Old 07-19-2005, 08:13 PM   #5
Captkaos
Captkaos's Avatar
That would make everything simpler. But I would switch bodies instead.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
