coil spring help!!
so when I bought my truck, it had a hokey suspenion lift, with REALLY tall front springs. Both ends were the same, as in no big and small end. My question is, which way does the small end go in, up or down? I have a '67 C20. thanks, Scott
'67 C20 LBW |
![]() Join Date: May 2011
Re: coil spring help!!
there is a "pig tal" end and a "square end" the pig tali end goes up into the crossmsmber and settles in a "retainer". If the pig tail end does not seet correctly in the upper cup it will sit funny. It is not a complicated process, just a paticular one. have fun.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
the big end should go in the bottom there is a recessed aera for the end of the spring rotate to that spot
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
that's what I thought, but wanted to be sure. thanks guys!!
'67 C20 LBW |
Tags |
coil spring, coil spring swap |
