06-30-2020, 10:54 AM | #1 |
70+ ( Old Skool Club )
Tining Cover Question
Okay engine gurus. Is the timing gear cover on a 350 the same as the one on a small block 400 ? While we are at it do those engines use the same dipstick ?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-30-2020, 01:42 PM | #2 |
Re: Tining Cover Question
Timing cover yes, I think the dip stick too but not certain....
06-30-2020, 02:25 PM | #3 |
It will depend on years of the block some are passanger and some are driver side
As long as they both have dipstick on same side your good to go just double check level reads correct I had a shiny chrome one that said full when engine was still a quart low |
06-30-2020, 09:58 PM | #4 |
60-66 Nut
All small blocks 1979 and earlier should use the same dipstick. In 1980 the dip stick was moved to the passenger side. The '55-'85 timing chain covers are all interchangeable.
07-01-2020, 02:18 AM | #5 |
Thanks for the info everyone. The dipstick on my engine block is on the drivers side and the casting number shows could be 79 or 80 block but I guess with Captainfab's info I guess its a 79 block. A friend has aboriginal 350 dipstick I can have now to find a good timing cover. I'm geting a SB 400 built for my 72 C10.
07-01-2020, 09:39 AM | #6 |
The timing cover seal changed in 74 or so. That could throw you a curve if one of those engines is older than that.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
07-01-2020, 10:10 PM | #7 |
60-66 Nut
The difference is in the front of the oil pan not the timing chain cover.
07-01-2020, 11:28 PM | #8 |
You can put the fat seal in the old timing covers? I guess my memory is getting foggy.
07-02-2020, 09:46 PM | #9 |
60-66 Nut
Yes, the timing cover channel for the seal are all the same until you get to 1986.
07-02-2020, 09:57 PM | #10 |
Again, thanks for the help everyone.
07-01-2020, 01:40 PM | #11 |
AG,
Good choice on the 400!!! All the timing covers mentioned WILL interchange! BUT, the time mark can be in different places for the specific balancer used. A 400 takes the largest balance that was used on a small block, I believe 8 inch. You may be able to/or have to install a bolt on timing tab. It attaches to 2 of the timing cover bolts Man I have a built 400 I plan to put in my 67 C10. Need to install an old 283 first, just wanting to get it running. It will take more $$$ for better tranmission and rear end parts for the 400 install... |
