Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 09-22-2009, 03:11 AM   #1
John Pasinski
John Pasinski's Avatar
Grill polish
What's the best way to bring a used outter grill back to life? I've tried aluminum polish and stainless polish without getting good results. Am I just not putting in enough elbow grease? What are they made of anyway? Stainless OR aluminum? Also the inner grill; what can I clean those with? Mine's pretty stained from years of neglect.
John Pasinski is offline   Reply With Quote
Old 09-22-2009, 04:47 AM   #2
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
Re: Grill polish
Theirs been alot of differant ideas as to what works best,sanding,steel wool,metal polish,and even oven cleaner.I have not got to the grill on mine yet,but if you search this site or checkout the detail section you may find other ideas.
1970 Bowtie is offline   Reply With Quote
Old 09-22-2009, 07:07 AM   #3
cdowns
cdowns's Avatar
Re: Grill polish
the grill is anodized from the factory. to polish the grill the anodizing must first b removed so you can get to the aluminum to polish it
Old 09-22-2009, 02:36 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Grill polish
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-22-2009, 02:47 PM   #5
UltraBlue71
UltraBlue71's Avatar
Re: Grill polish
Mine was so trashed I just painted it the same color as the truck after nudging the dents out of it. Untill I can afford a new stainless one that is! Good luck getting it to polish, I like the mothers aluminium polish...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 09-22-2009, 04:27 PM   #6
cl79c10
cl79c10's Avatar
Re: Grill polish
I did my grill a few weeks ago I tried the oven cleaner thing but it did not work. So I just sanded her down and polished her right up. Take the grill off the truck first.
Here is a photo of my grill now keep in mind it was scratched up pretty bad before.
cl79c10 is offline   Reply With Quote
Old 09-22-2009, 06:11 PM   #7
John Pasinski
Re: Grill polish
OK all...............I will just keep on; keepin' on. Thanks for the advice.
Old 09-22-2009, 07:26 PM   #8
Chada
Re: Grill polish
Where can you get a stainless one?
Chada is offline   Reply With Quote
Old 09-22-2009, 07:31 PM   #9
ortegamotor
ortegamotor's Avatar
Re: Grill polish
here is a picture of my old 69 grill. i removed the anidized coating then polished on a buffing wheel. good luck with your project. Tony
ortegamotor is offline   Reply With Quote
Old 10-07-2009, 04:35 PM   #10
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Grill polish
How did you remove the anodizing?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-07-2009, 01:25 PM   #11
UltraBlue71
Re: Grill polish
Chada, LMC in Lexena KS has them, they are pretty proud of em tho....
71 LWB
Old 10-07-2009, 03:38 PM   #12
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Grill polish
LMC doesn't have stainless steel grills. They have aluminum, steel, and chrome plated steel. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-07-2009, 03:56 PM   #13
scottrod71
scottrod71's Avatar
Re: Grill polish
Mine was in good shape except it was etched by a harsh cleaner by the prior owner. I opted to powder coat it. Supposed to be a "chrome" powdercoat but not bad and certainly better than it was and cheaper than LMC's $660 grille. I paid about $125 and it took 3 days.
scottrod71 is offline   Reply With Quote
Old 10-07-2009, 05:07 PM   #14
fun in dirt
fun in dirt's Avatar
Re: Grill polish
I used oven cleaner to get the clear anodize off. And get the smelly expensive kind...I tried the "fume-free" and it doesn't work near as good. Soak the grill down good (after removing all the plastic inserts & such) and let it sit till you see the clear bubbling up. Then scrub it good with a brush before rinsing it off. Don't forget to wear rubber gloves & safety glasses while doing this all.
It may take doing this two or three times to get it all off.
If the grill is scratched up, sand it till scratches are gone then start increasing the paper grit until it gets smooth. Using aluminum polish is the last step. But if you want a clean, dull, brushed look...finish it off by rubing with a green scotchbrite pad & WD40.
This is what worked for me!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-07-2009, 05:27 PM   #15
BIG ORANGE
BIG ORANGE's Avatar
Re: Grill polish
www.eastwood.com sales a kit you mix with water and you can strip any of the ole aluminum trim pieces on the truck molding! Afterwards get a buffing wheel and some compound and make it look new again!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 10-07-2009, 06:35 PM   #16
UltraBlue71
Re: Grill polish
My bad guys they dont have a Stainless grill! On page 71 of my LMC catalog they have the
"paintable" steel black one for 299.95 Chrome Steel one for 399.95
Aluminium one for 299.95
I stand corrected!
71 LWB
Old 10-08-2009, 12:08 AM   #17
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Grill polish
I don't understand why everyone wants to remove the anodizing from their grills. If you do, after a short time the aluminum will dull and you have to keep polishing it over and over again. The anodizing protects the aluminum and keeps it shiny. BTW, those chrome plated steel grills from LMC are only available for 71-72 chevy trucks.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-08-2009, 04:08 AM   #18
sameyrasmea72
sameyrasmea72's Avatar
Re: Grill polish
If a 37+ yr old grill is dull and still has the anodizing on it, there is no good way to make it shine again without removing it. Removing it may cause other problems but I don't know of a way to make an old grill shine.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 10-08-2009, 04:43 AM   #19
unclewatts
unclewatts's Avatar
Re: Grill polish
Sounds reasonable.
Old 10-09-2009, 03:28 PM   #20
storked82
storked82's Avatar
Re: Grill polish
HI Guys
Just had to say those pictures of your trucks are AWSOME very good looking trucks
Take care
Jeff Main
storked82 is offline   Reply With Quote
