12-16-2011, 11:34 PM | #1 |
Junior Member
Key on power during crank
Im just finishing up wiring on my 69 lq4 swap and have noticed that i loose key on power during crank, I tried the ignition switch from my other 69 and same thing. Just wondering what everyone is doing to solve this
12-17-2011, 12:54 AM | #2 |
Has more rust than truck...
Re: Key on power during crank
Where are you getting your "trigger" for your key on relay? On mine I replace the stock red resistor wire that went to the coil with a normal 14ga wire and it keeps power during crank.
12-17-2011, 11:12 AM | #3 |
Junior Member
So far im still trying to figure out where to get key on from. Ive checked both of my ignition switches with a multimeter, and all but the starter feed goes dead during crank
12-17-2011, 12:51 PM | #4 |
The ignition switch in mine is from a '72, maybe there is a difference.
12-17-2011, 01:08 PM | #5 |
I would use the wire that originally powered your distributer/coil, that will have power while cranking.
12-17-2011, 10:59 PM | #6 |
Still Just Havin Some Fun!
Thats what I used.. Works perfect!
a green one with some stuff done to it.... |
