07-06-2012, 05:18 PM | #1 |
59 power window install help
Hi Did i buy the right power window kit? Dolphin window thru e-z wire,i have never put power windows in before so a couple dumb questions,I did not remove the brace that ties the inner and other door skins together and the window kit does not seem to fit on top or below brace,do i have to notch brace also it looks like i have to cut or shorten channel to get window to come down or up the right height and it seems like it still will hit the support brace in doors. any comments positive or negative or better yet point to where i can see pictures. i am keeping the vent window in. thanks mike.
07-06-2012, 08:39 PM | #2 | |
Re: 59 power window install help
wayne |
07-07-2012, 08:07 AM | #3 |
Thanks Wayne, The ne-relics kit look good,I should have asked more questions before i bought. I will work on mine a little longer before i buy a new kit. thanks Mike
07-07-2012, 09:23 AM | #4 |
I wouldn't cut the brace. You would likely end up with a road noise amplifier.
07-09-2012, 02:36 PM | #5 |
don't be afraid to cut, just make sure you need to cut...
this is what i had to do to get my 06 dodge durango freebies in
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-10-2012, 11:30 PM | #6 |
Thanks Ogre, Im starting to drive the truck around town to work the bugs out so i have put the power windows on the back burner,Im ok with cutting the interior door panel up,just need to take my time and be smart about it. thanks,Mike.
07-11-2012, 05:20 PM | #7 |
i mocked up the durango window motors on a piece of wood before looking at my doors to get the mounting points
and then transferred the mounting points to my doors before cutting i have zero dollars invested in my power windows other than the wiring and switches everything mounts to the removable door panel, the holes are access to fasteners i have little talent, but unlimited tenacity
07-12-2012, 03:54 PM | #8 |
I was looking in a catalog for power windows in my 56 & the co. I saw showed the custom kit for that era as being for changover to 1 piece window only. You might check your aplication.
