Yellow truck club
fan placement in shroud
Where should the fan be sitting in the fan shroud? Should it be completly inside or just in front of the opening?
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: fan placement in shroud
The blades should be half in/ half out for maximum efficiency.
Chris
x2....
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
its all about the +6 inches
yep. If it is inside the shroud, then it just blows the air around inside the shroud... stirs the air up. If it is outside, then it'll pull air from around the shroud as well as through it. 1/2 in and 1/2 out is the best location.
