05-04-2014, 12:59 PM | #1 |
Power steering gear box fitting
I am swapping to a 99 4.8l and i was wondering if anyone knew if there is an adaptor fitting or what the original threads are on the pressure hose and the factory gear box. Or just what you did thx so much guys
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
05-04-2014, 01:25 PM | #2 |
Re: Power steering gear box fitting
If you had power steering on your truck just remove the fitting, spring and valve in the old pump, everything should be the same!
05-04-2014, 01:54 PM | #3 |
Oh awesome! Thx i never even thought to do that. Are the pressures between the pumps close enough to where i dont have ro worry about blowing out seals etc
05-04-2014, 02:02 PM | #4 |
i just swaped the fittings out when to the junkyard and got one off a 73 chevy van screwed into ls pump used a stock hose and a used gear box i had off a parts truck no issuses yets swap everything out of the back of the pump fittign vavle and spring and it will feel like stock power steering
05-04-2014, 02:11 PM | #5 |
Awesome thx
05-04-2014, 04:56 PM | #6 |
I did not swap the spring and valve (yet) from my pump on the 350, and the steering is VERY "loose" feeling, I need to change the internals!
05-05-2014, 12:33 PM | #7 |
Same here, I had the LS style o-ring/fitting and swapped to an earlier flare style fitting. I haven't fired it up yet with this set up but I did use the early spring valve. The spring looked the same but the valve appears to have a different size hole.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
05-05-2014, 06:31 PM | #8 |
Can anyone take a picture of the spring and valve? I am curious my old pump or the new ls pump have one.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
05-05-2014, 07:09 PM | #9 |
i believe this is the right pictutre
05-06-2014, 12:44 AM | #10 |
Do you have the new one from the LS pump to compare the length with the old one, and did you change the spring also?
05-06-2014, 01:04 AM | #11 |
05-06-2014, 02:29 PM | #12 |
How many washers are under the nut on the left side of the valve?
05-05-2014, 07:15 PM | #13 |
Interesting. Where does it go on the pump exactly?
05-05-2014, 10:38 PM | #14 |
On back of tge pump where the hose screws in it is a 1 inch fitting unscrew thst there is a vavle and spring behind tye fitting
05-05-2014, 11:22 PM | #15 |
Old member
I also took the fitting off my old pump and just put it on the LS pump and it works great. I also have new S/S hoses coming from (PICKMUP)
a memeber on here for it. Here is his link. http://67-72chevytrucks.com/vboard/s...hp?t=545846You
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-25-2019, 12:41 AM | #16 |
05-06-2014, 12:37 AM | #17 |
Behind this nut?
05-06-2014, 09:21 AM | #18 |
yes take that "nut" out and it is the fitting. What I show in this pic is the newer metric 18mm o-ring fitting. I the valve and spring is behind this. Just unscrew this out and swap your old one in. Now I don't remember 100% and I don't know if I swapped the guts out or not. I need to look in my old pump. cause I just put it all back in the old one for safe keeping.
I did mine about 10 years ago and not had any issues. I am about to swap to hydroboost and thought about using this new style fitting and stuff but it sounds like maybe I better just stick with what is currently in there and use it with the right hoses.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-06-2014, 02:24 PM | #19 |
Old member
I swapped it all out of my stock 71 pump.
05-06-2014, 12:40 AM | #20 |
Better pic
05-06-2014, 02:35 AM | #21 |
I do not I got that picture off the Web to show what it looks like. Yes behind that nut I know my steering feels great I swapped fitting spring and valve out of a 71 Chevy van
02-04-2016, 04:47 PM | #22 |
Does someone sell an AN jic adapter fitting for the late saginaw (o ring) fitting style out of curiousity?
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
02-04-2016, 05:01 PM | #23 | |
-6 AN to 16mm x 1.5 o-ring seal - 648060 -6 AN to 14mm x 1.5 o-ring seal - 648070 -6 AN to 18mm x 1.5 o-ring seal- -648080 |
02-04-2016, 09:08 PM | #24 |
I have a set i got of a guy on ebay for the box end. And a set for the future up grade to hydro boost when i have a job again someday. Laid off from the oil patch since last July. Thank you for the part numbers!
04-08-2016, 04:42 PM | #25 |
Found this adapter on ebay: http://www.ebay.com/itm/161997290924
