what lowering blocks do i need
This is the piece of the flip kit from po. I am doing an aol and want to add 2 inch blocks tho my flip kit. Can anyone recommend a set of blocks that has the holesthat line up with my flip kit?!?!
http://i208.photobucket.com/albums/b...r/CAM00116.jpg |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: what lowering blocks do i need
You will have to make them.
Yeah with a axle flip kit there is no lowering blocks unless you want to cut off your spring perches move them to the bottom of the axle.
thanks guys, i think i am going to maybe try and making some using some rectanglur steel tubing i guess......
I've made a set of lowering blocks for the exact application you are talking about.
I used the design that I saw from JTR's website. http://www.jagsthatrun.com/Pages/Par...y-U-Bolts.html (The version on the left) I used solid 2" stock and drilled the bottom for the leaf spring "centering pin",... and then used a 3/8" allen head cap screw for the lowering block pin that will indicate on the flip kit bracket. Just offset the indexing pin hole and cap screw to match the flip kit bracket,... and you will be good. The picture below is for S10 lowering blocks. So your block dimensions may be different than this picture shows.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-06-2013 at 04:57 PM. |
YES! i am glad someone is on the same page with me!
that is what i was thinking of making, but i was wondering if all that 'stacking' of parts would be alright. i will also be having a bracket under the block and between the leaf that extends out and the air bag sits on. i was thinking of maybe using steel tubing inplace of the solid aluminum and welding all of it together? but the solid aluminum seems easier to do for me.... Last edited by northeimcustom; 02-06-2013 at 07:14 PM. |
I think your u-bolts will keep it all together.
You will have to buy new longer u-bolts anyway.
