Old 07-21-2009, 06:11 PM   #1
Dino11
Dino11's Avatar
how to shave drip rails...?
i searched and found a little info, but not so much a how to, which is what i am kinda looking for...
i am a bodywork amateur, and i think the drip rail kills the look of the truck... so i was wondering how hard is it to smooth this, what exactly is the best way to go about it? is there more than meets the eye? what process and techniques are there? thanks so much!
72 c-10 lwb: mild 350 , turbo 350 w shift kit, 3.73, drop spindles and rear drop springs, e-fan, relocated fuel tank, roll pan,
Progressive wheels, 02 silverado buckets&console
Dino11 is offline   Reply With Quote
Old 07-21-2009, 06:49 PM   #2
mclairmo
Re: how to shave drip rails...?
Have not done it but read that it is more work than it seems. Apparently, there are several layers of metal there that have to be welded and smoothed.
mclairmo is offline   Reply With Quote
Old 07-21-2009, 08:17 PM   #3
lotik
drag it like you stole it
I took a sawzall and cut off about 6 inches of driprail then tacked up that section. I repeated this all the way across. Its definitely a lot of work. Have fun.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 07-21-2009, 09:12 PM   #4
Dino11
Dino11's Avatar
hm, i figured there were several thin layers to deal with... this is on my to do list.. and i will do it sometime lol... ill try to do a write up on it when that day comes
Old 07-21-2009, 09:28 PM   #5
eseaton
eseaton's Avatar
I just finished mine, its realy not that hard just take your time, work in small sections, and keep the heat to a minimum. And dont dig in the grinder when smooting the welds.
67 GMC SW 383 stroker/TH350 w/ 4.56 gears - under construction
04 GMC 1/2ton daily
07 GMC Acadia wifes daily
eseaton is offline   Reply With Quote
Old 08-17-2009, 09:13 PM   #6
Strodder
Daring to be Different
Strodder's Avatar
I made the drip rail into a flare, and shaved the back part of the drip rail after the door.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-17-2009, 10:57 PM   #7
Ackattack
Ackattack's Avatar
I did this on my 68....you can see the pictures and read about it in my build thread.
Here's what I did. First, practice on a junk cab. Really, this is what I did.
On the real thing I started by cutting off a short section of the driprail about 1/4" from being "flush" and then tacked that back together in just a few spots. I did this all the way across the front. Then I came back with a grinder and ground the remaining seam back down flush with the widsheild and roof. If I remember right I also had to do a little messaging with a body hammer too.
So there is the front part.
The sides are a little easier. First, part of the drip rail is a seperate piece and tat came off, then I pretty much just cut and removed the rest, and welded it back up. Sounds pretty easy but man, some of that metal, especially around the back curve is THIN and very difficult to weld.
After I did this there was a sharp "edge" and a large gap between the door and the cab, so I took some 3/8 rod, bent it into shape and used it as a filler piece between the door and cab. This also smoothed out the sharp edge.
Good luck....lots of work!
Here are some pics:
before body work (what I did)
after body work (no paint)
Ackattack is offline   Reply With Quote
Old 05-12-2010, 06:53 PM   #8
chevyz71z28
chevyz71z28's Avatar
For the first peice that you removed around the door what is the best way to remove it? also do you d o anything with the Appilar cause it looks like if you cut off the drip rail then the appilar won't sit quite flush with the roof? I am planing to give this a try pretty soon and just want to know the attack plan first. Thanks
chevyz71z28 is offline   Reply With Quote
Old 05-12-2010, 07:11 PM   #9
dnd1978
dnd1978's Avatar
It is a BIG job. Read this it all help.
http://www.customclassictrucks.com/t...rty/index.html
dnd1978 is offline   Reply With Quote
Old 05-12-2010, 07:32 PM   #10
ivanuf2
ivanuf2's Avatar
Has anyone experienced any problems with water dripping inside the cab with out the drip rail. Is this a viable mod for a daily driver or just for show trucks. I was told by other truck owners not to do it because I was going to have water problems. Any feedback form users?
ivanuf2 is offline   Reply With Quote
Old 05-12-2010, 09:30 PM   #11
Ackattack
Ackattack's Avatar
I have not driven my truck in the rain yet, but I did take it to the car wash and didn't get any water from around the door.
It takes a little work to get the A-pillar to look right. I cut a slice in the roof from the corner to the middle and did a little hammering to smooth it out a little. The body guy took care of the rest.
Old 08-18-2009, 01:59 AM   #12
Dino11
Dino11's Avatar
Awesome info and ideas! Keep em comin!
I am hopin to get sum cash and get a parts truck if i can , honestly id like to swap cabs if i could find one a lil better, so this may b my practice truck.
What is the tool that you guys have used to cut this off?
Old 08-18-2009, 11:22 AM   #13
vegaschevy
I have heard said they used a sawz all, or a 4" cut off wheel.
vegaschevy is offline   Reply With Quote
Old 08-18-2009, 11:29 AM   #14
Strodder
Strodder's Avatar
I used a 4 1/2" cut off wheel, on a electric side grinder.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-18-2009, 11:49 AM   #15
Ackattack
Ackattack's Avatar
me too
Old 08-18-2009, 02:30 PM   #16
Strodder
Strodder's Avatar
Originally Posted by Ackattack View Post
me too
I have a plasma cutter that's needs a circuit board. That board is over $500.00, so it's just sitting. It's an over kill for drip rails though. I miss the plasma cutter when I need to cut thicker metal.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 12-14-2014, 08:14 PM   #17
Possmguts
Possmguts's Avatar
subscribed for later reading
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
