Old 04-03-2018, 08:36 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Shaving a Auto tilt
As the title states. I'm going to shave a auto tilt to go in my ramp truck that has a 4 speed. It will be a little of everything. Welded and body filler depending on the area. Mostly welding I hope. I'll paint it after it's all done to hide the mistakes!
I have never done one before so any suggestions are welcome. It will be a learning experience I'm sure but it will be done!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-03-2018, 08:57 PM   #2
Robznob11
Robznob11's Avatar
Re: Shaving a Auto tilt
I didn't go to that extent but I did shave the shifter arm off. I did not weld, I used fiber strand!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-03-2018, 09:10 PM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: Shaving a Auto tilt
Is this some kind of fiberglass?
Dieselwrencher
Is the cup even aluminum or pot metal?
It's just plain metal as far as I know.
Old 04-03-2018, 09:16 PM   #4
Robznob11
Robznob11's Avatar
Wink Re: Shaving a Auto tilt
Yes, I think i said it wrong it is Martin Senior fiber hair. You can get it at napa. It is a body filler but it has long strands of fiberglass in it. Sets up like a rock. The fiber strand gets rock hard to but it appears more like filler (you cannot see the fiberglass in it) I use the strand on my initial body work (rough work). Then I use light weight over it. The hair is better option for the column. You can use screen with hair over the top. Then use grinder to rough shap it. And regular filler over the top.
LED TAILS
Old 04-03-2018, 09:22 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Shaving a Auto tilt
Cool. I pick some up and work with it. Thanks. I was going to have my neighbor weld most of it but this may be much easier and I can do it myself.
Old 04-03-2018, 09:05 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Ryan
1969 Chevy milk truck
Old 04-07-2018, 10:51 PM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Shaving a Auto tilt
I found out today after welding didn't work the bowl is aluminum(first picture) and the rest is metal. So I cleaned it all up again and filled the openings with plumber's putty like I used on my steering wheels that I have re done. I will let it dry for a few days then sand it down and primmer it to paint. Going to paint it black.
I also used the safety neutral switch screw holes with long screws to secure the shift tube in place then I cut the bottom part off.
Old 04-08-2018, 11:29 AM   #8
Andy4639
Old member
Andy4639's Avatar
Got the rough sanding done. Now waiting on warmer weather to primmer it and final sanding. Then I'll paint it.
Old 04-08-2018, 12:54 PM   #9
rvrfoot
My friend used jb weld.
rvrfoot is offline   Reply With Quote
Old 04-08-2018, 06:16 PM   #10
Andy4639
Old member
Andy4639's Avatar
I got to thinking about it. The filler want have any pressure on it and it want have any stress so I just used what I had. This stuff gets hard but it is easy to work with.
Old 04-03-2018, 09:21 PM   #11
Dieselwrencher
I've done what Rob has done in the past too. It used to be called tiger hair in the day.
Ryan
Old 04-04-2018, 12:57 PM   #12
67chevemall
67chevemall's Avatar
Going to turn my auto into a manual column too.
Great ideas here
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-04-2018, 04:09 PM   #13
demian5
demian5's Avatar
I would have probably completely disassembled it first to prevent shavings from getting into the bearings and causing potential shorts.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-04-2018, 09:07 PM   #14
Andy4639
Old member
Andy4639's Avatar
Shorts how???
I plan to blow it out good with air after wards plus I put foam down inside it while I cut it and grind it.
This want need the safety neutral switch. I used them to drill into the shifter tube to hold it in place. Works like a champ. I'll cut the lower lever off tomorrow night.
Old 04-08-2018, 09:23 PM   #15
72LB
72LB's Avatar
I found a shift delete collar from a dump truck a while back, plan on using it on mine when I find a manual column.
72LB is offline   Reply With Quote
Old 04-09-2018, 06:14 AM   #16
Andy4639
Old member
Andy4639's Avatar
Not sure I am following what your saying here?
When I pull the one out of the ramp it's for a 3 on the tree column shift.
Old 04-09-2018, 04:19 PM   #17
72LB
72LB's Avatar
Shift delete collar doesn't have the opening for the shift arm it's smooth all around.
Old 04-09-2018, 04:31 PM   #18
Andy4639
Old member
Andy4639's Avatar
Yes I understand I know this part.
This is what I was talking about. How will this bowl work for a manual column?
Are you trying to say for a 4 speed?
Old 04-09-2018, 09:04 PM   #19
72LB
72LB's Avatar
It cleans up the column so I can use a floor shift.
Old 04-10-2018, 06:16 AM   #20
Andy4639
Old member
Andy4639's Avatar
Ok that I got. When I do my swap your welcome to mine. It's the old 3 on the tree column but it's not tilt.
Old 04-10-2018, 09:23 AM   #21
72LB
72LB's Avatar
Cool, I prefer one that doesn't have tilt.
Old 04-10-2018, 11:09 AM   #22
hayhauler71
hayhauler71's Avatar
JB weld on this one
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-10-2018, 11:44 AM   #23
Andy4639
Old member
Andy4639's Avatar
Originally Posted by hayhauler71 View Post
JB weld on this one
That looks good sir! Nice job.
Old 04-10-2018, 11:34 PM   #24
rvrfoot
JB weld on this one
Where did you get the inter shaft and the end?
Old 04-11-2018, 09:07 AM   #25
hayhauler71
Inner shaft is the original. And the joint I bought online stainless steel I believe it is 3/4 DD to 36 spline to replace the factory joint.
Fuzzy
