02-16-2017, 03:57 PM | #1 |
head gasket
wanting to lower my compression a bit and seen https://www.summitracing.com/parts/f...make/chevrolet
and noticed 1 the bore size and 2 the steam holes in the gasket. Is this to much for the bore on a 383 stroker? and can I use it with the steam holes in it? |
02-16-2017, 08:32 PM | #2 |
Fabricate till you "puke"
Re: head gasket
The 4.166 bore gasket is the one you want on that 4'"+.030 bore engine. I would ask a few questions, before I advise? can you give a run down on comp ratio, deck clearance, cam specs, ect. ? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-19-2017, 12:29 AM | #3 |
Re: head gasket
Crazy Longhorn asked some good questions.
Also, what is the reason for wanting to lower your compression? Sometimes, using a thicker head gasket will actually make an engine more prone to pre-ignition because of the increased "quench height". If you already have a pre-ignition problem, perhaps optimizing ignition advance curve can help.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
