01-11-2015, 02:32 PM | #1 |
I was bored, so I made a cold start video!
I'm running a brand new engine :
GM Part # 19210008 - 350 / 330 HP Exhaust : Dual 2 chamber flowmasters dumped before the axle. Stock ramhorn exhaust manifolds https://www.youtube.com/watch?v=inld6rvyC2g
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
01-11-2015, 03:26 PM | #2 | |
Re: I was bored, so I made a cold start video!
You are KILLING me here lol! Let's see a burnout! |
01-11-2015, 04:20 PM | #3 | |
I had some issues with the shop that did the install. They hooked my vacuum lines up all jacked up and a few other things that really made me doubt their skill level. So far everything seems to be ok now that I've gotten everything routed correctly. Also this engine came with a Holley 670 carb.....the shop that did the install couldn't get it running good with that carb, so I got frustrated and told them to just put my old Edelbrock 1406 that I had on the original engine ......on this engine. So far it's running pretty good. I still think the carb needs some adjusting and maybe the timing needs some tweaking too....I also have been having a problem with my detent cable since I got the new engine installed. It will not kick down into gear when you floor it at any speed. I even took it to the transmission shop that did my rebuild about 6 months ago.....they said the cable was messed up and they installed a new cable.....they told me it was working and to come pick the truck up......after I picked it up......it still wasn't working.....I called the shop back and they played dumb.....they told me to bring it back but I haven't yet....I've had bad luck with every shop that has worked on this truck.....seems alot of mechanics don't know much about these old trucks....I need to find an old timer who knows what the hell he's doing... I did however decide to manually shift it one night and let me tell you.....it ran like a raped ape.......it was pretty impressive for a 3/4 ton truck.....I only made a few hard passes since i didn't want to dog on it too bad yet.....I think once I get the detent cable working and get the engine broken in....I think I'll be very happy with this engine!!!
01-11-2015, 05:45 PM | #4 | |
Any hope of using the Holley would require a custom bracket for the detent cable, and I wonder if that's why the shop said "it wouldn't run right". They may have fudged the truth a little on that one. This might help with the Holley: https://www.holley.com/products/parts/20-121/ Detent cable, hmmm.... If it worked on the 1406 on your old engine, and if it bolts to the carb itself, then it should work. However, if it bolts to the intake, you might want to try another bracket. http://www.jegs.com/i/Edelbrock/350/...56#moreDetails I hope the trans shop gave you back your old cable or at least the new one is identical to the old one so it fit's your 1406. The geometry gets tricky on 700R4 and 2004R's because the cable also controls line pressure (no modulator valve), but on a T350 you are just looking for a throttle angle at which point the DETENT pressure rises enough to initiate a detent (kick-down, it has modulator valve to control line pressure). Check the cable adjustment, you may need to move the slider farther away from the carb to get it to kick down (see figure but ignore the part that says move slider this way for adjustment that is for factory installations where you floor the throttle to adjust it after it's all the way retracted as it will pull out that way if forced it's just a coincidence that you probably need to go the same way). One would think this has already been tried, but we cannot take anything for granted. If this won't do it, and you think it needs to move in this direction, try this. Check out the inner cable itself, the part that moves, and see if there is slack in it if it does not have resistance in the cable when the throttle is open. You might be able to get a cable stop to effectively shorten it but only if the bracket that holds the cable was moved closer to the carb. For temporary you can take some pliers and install some lead fishing sinkers between the factory cable stop to see if that moves you in the right direction. If you have the other type detent cable with a long open slot, you may have problems as the bracket needs to be in the exact correct spot, and you might need to convert to the cable with the plastic end. |
01-11-2015, 08:10 PM | #5 | |
Thanks for all the info man! I have the TH350. I'll get a picture tomorrow of the way everything is hooked up and see if you have any comments. I'm hoping that maybe the cable isn't fully extending at WOT....so if this is the case then I just have to move the bracket further back towards the firewall....and or make more adjustment on the cable itself. The weather is crappy here and it's getting dark, so I'll try to post some pics tomorrow!
01-12-2015, 12:37 AM | #6 |
Nice truck and video ,, she sounds nice I have that engine in my C20 also... It scoots around just nice
72 C20 Longbed 05 1500 Z71 |
01-12-2015, 04:04 PM | #7 | |
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
01-11-2015, 04:03 PM | #8 |
Nice truck. What size are your tires?
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
01-11-2015, 04:26 PM | #9 |
01-11-2015, 05:07 PM | #10 |
The Niner
Lookin good!!!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
01-12-2015, 11:03 AM | #11 |
I had a 330 horse HO motor in my 68 camaro that I just sold ,, solid solid motor ,,, what GM does not tell you is the HO motor is equivalent to the old zz4 ,, if not more powerfull thanks to the vortec heads ,,, the zz4s had junk lt4 heads ,,,, the HO's were rated with a 600 carb ,, thats why the lower top end number ,,, the new zz5's are a different animal ,,, they changed the heads to fastburns and picked up 50 hp ,,, moral of the story 350 HO is an excelent motor ,,, power ,,, mileage ,,, and clean running ,,, good for towing also ,, from the broad torque range ,,, IMO the HO is a better engine than the more expensive zz4 was ,,, if you tow heavy loads ,, the 383 high torque is a monster
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
01-13-2015, 11:02 AM | #12 |
Great Thread! Good info on the motor, good info on getting it and the trans to run correctly. These are the threads that make this forum so great!
01-13-2015, 04:49 PM | #13 |
sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
01-13-2015, 05:47 PM | #14 |
ok guys, so my latest issue is I'm getting a little intermittent slight bogging / power loss right at initial WOT....it goes away quickly and doesn't do it all the time so I don't think it starving for fuel because way higher into the power and RPM's it's not struggling at all.....what can this be??
The other issue is I'm still having some hot start issues (not related to the starter).....it's flooding.....I looked in the bowls after it's sat and there is no percolation or dripping....my guess is heat.....I know Holley makes a heatshield but I have a Edelbrock square bore # 1406.....is there a heat shield I can use or should I just get a 1" phenolic spacer? And finally one more thing.....the transmission shop got all my shift points great at normal driving....but at wide open throttle the 2nd to 3rd shift comes too early....it's fine at light to moderate throttle....only shifts early at hard WOT.....is there a way to adjust this without changing the 1-2 shift points....I like where the 1-2 is and don't want to mess with that part... Any help is appreciated....I've almost finally got my truck completely sorted thanks to all your help
01-14-2015, 01:16 PM | #15 |
I don't know about tranny adjusting, but as far as the WOT lag, it could be jetting, or timing sounds like. Is it under hard acceleration at WOT, or slowly getting to WOT. If it bogs when you slam on the gas, you need to check your power valve circuit in the carb.
01-14-2015, 01:43 PM | #16 | |
"There are two sets of rotating weights in the governor. The heavier, outer weights act at low vehicle speed and the lighter inner weights take over at higher speeds, especially during full throttle conditions. Centrifugal force acting upon the weights controls the opening and closing of the governor valve itself. The valve controls governor pressure delivery, which in turn controls upshifts". http://www.dragracingonline.com/tech...vi_9-bm-1.html Or if you are game remove the gov cover and gov, get a hemostat (fine needle nose easy to manipulate) of the smaller variety and install a weaker gov spring to the inner weights only. You may have to repeat to get it where you want it. If your gov cover has a clip good if it don't get one so you don't have to silicone it on and pound it off every time. http://www.ebay.com/itm/Governor-Cov...-/201244248113 |
01-14-2015, 02:33 PM | #17 | |
Does it take a long time to run right warming up? Check the total timing and let us know what that is and where the base timing falls. |
01-14-2015, 02:41 PM | #18 | |
In the above statement, I don't see anything that makes me think a phenolic spacer will help, although it will not hurt. Also you said it's not starter related so I assume cranking speed is OK. The deluxe engine came with an HEI, right? Did you old engine have points? What gauge is the wire going to the HEI, it's not the old wire for the points is it (resister wire)? What you describe fits what happens with that problem. |
01-14-2015, 05:58 PM | #19 | |
Yes the engine came with the HEI.....I have a suspicion that they may have hooked it up wrong wiring wise but I really don't know...how can I check? The shop that did the install did it.....if the way they hooked up the vacuum lines originally are any indicator then who knows....lets just say I wasn't completely happy with their job in some areas... I'm getting really bad gas mileage too....like 7 MPG....however the instructions for this engine recommend this on the timing : "Set spark timing at 32º before top dead center (BTDC) at 4000 RPM with the vacuum advance line to the distributor disconnected and plugged. This setting will produce 32º of total advance at wide open throttle (WOT). The HEI vacuum advance canister should remain disconnected. This engine is designed to operate using only the internal centrifugal advance to achieve the correct timing curve." That is what they said they set it at.... It's currently showing 12 degrees BTDC at idle....with the vacuum advance plugged. The bog only happens sometimes, and it just right when you floor it as it's kicking in....once it kicks in it's fine....no bogging or struggling after that...
01-14-2015, 06:34 PM | #20 |
I just talked to the shop that did my install....they said they just used my old coil wire and hooked it straight to the HEI....FML....
It's insane....this is a restoration shop and shop that's been there since 1977
01-14-2015, 10:54 PM | #21 |
I can check it out this weekend. I have the correct Packard 56 terminals and crimper to run you a new wire from the firewall block to the disributor if it needs it
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
01-14-2015, 10:58 PM | #22 |
you're the man!!
02-19-2015, 12:15 AM | #23 |
Mechanicalman....
I have learned a wealth of knowledge from you.....am setting up the same thing in a 68 C10..... 1972BlueC20.....I'm out in Katy.....after I'm done, I'll contact you and compare some notes. Thanks guys!!!! |
