08-09-2008, 11:35 PM | #1 |
Automatic floor shifter
Looking for a automatic slap style shifter fit for a truck. Now I've seen the car style ones mounted high up, but this doesn't look good to me and it takes up a lot of real estate on the floor. I'd like something with a longer stick that's meant for a truck. Do these exist, and what you are all using in the way of shifters ?
1977 GMC Sierra Grande |
08-10-2008, 03:06 AM | #2 |
fugedaboutit
Re: Automatic floor shifter
They make a truck mega shifter that sits up a little more than the car version, but if you think they take up too much space check out the lokar products.. very slick
Currently truckless |
08-10-2008, 08:12 AM | #3 |
here's mine on some square tubing and a plate, i don't think it looks to bad.
08-11-2008, 08:50 PM | #4 | |
I agree with Regan and like your dash. They say that was redesigned to make the gauges more visible around the wheel. Is it a good improvement? If so I'm going to order one myself. Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
08-11-2008, 10:44 PM | #5 |
Thanks, the dash is from nolimit. The only problem i had was that i had to trim some of the dash behind the guage panel where the lights and the windshield wiper switch were relocated. Other than that i do like it alot.
08-12-2008, 12:21 AM | #6 | |
I may just bite the bullet and take a car style shifter and just build it up on a taller base. Probably the easiest solution.
08-13-2008, 02:14 AM | #7 | |
64 Chev c-10 LWB. 383 STROKER TH400 ps, pb. |
03-14-2009, 02:00 PM | #8 | |
Thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
08-11-2008, 10:47 AM | #9 |
That instrument panel is cool !
NHRA Super Street 469C It only runs 10.90 at 156 mph Last edited by regan wilson; 08-11-2008 at 10:48 AM. |
08-11-2008, 11:17 PM | #10 |
It depends if you want to bend over to shift,and if you want to shift fast or not,if so design a nice console and get a short shifter,and I agree thats a nice dash 69,I'm glad you all are'nt broke down now anyway,My $$**$$***+++ cam ate 4 in and 6 ex lifters I just found out today and its motor time again,I'm thinking about building the 400 SB now!!!
Built chevy tuff! |
08-13-2008, 08:24 AM | #11 |
i like that now.....makes me wanna install one of those in my truck.
08-13-2008, 10:28 PM | #12 |
That's good lookin, too bad it's not a ratchet style otherwise i'd buy one right now.
Whats everyone's favorite ratchet/slap style shifter for a street/strip truck that will see some track time ? I don't know much about these as I've never driven a vehicle with one.
08-14-2008, 11:13 AM | #13 |
I use a B&M ProRatchet and love it . I have always liked a ratchet shifter becuase you cant miss a shift . You might could call them and see if you could change the stick out for a longer one . Another thing is if you plan on doing any racing you will need a reverse lockout and a neutral saftey switch .
NHRA Super Street 469C It only runs 10.90 at 156 mph |
08-14-2008, 04:05 PM | #14 |
Here are some pics of my old B&M truck Mega Shifter and my new B&M Pro Stick installed.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
08-14-2008, 09:57 PM | #15 |
mini truck racer
I am a pro stick user also . I have the conventional handle and not the magnum . Also need to consider that when belted in the seat you have limited movement . If your belt are tight you need to be able to reach the shifter comfortably .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
08-16-2008, 06:40 PM | #16 |
I like the Hurst Quarter Stick, but it need to sit higher to be useful in our trucks.
08-19-2008, 08:53 PM | #17 |
I currrently use a B&M Pro Ratchet myself. Shifts are precise and you can't miss a shift. I use to use a pro stick, but found that, although the shifts are precise, when you get down in the 8.50 or quicker classes with a 3 spd. theres just to much to think about with a pro stick. I just like being able to use my shifft solenoid.
08-19-2008, 09:21 PM | #18 |
Here's a little better picture of my hurst quarter stick. Once it's out of park it's nearly perfect for shifting.
03-14-2009, 11:32 PM | #19 |
I'm rockin the truck mega shifter, i love it and i've got it at a perfect height, and i've got a bench seat, haven't gotten around to fitting the plastic console on it, but i will some day...
03-15-2009, 01:02 PM | #20 |
67-72 Addict!
I'm also using the truck version of the megashifter. Here is a pic showing the car version next to the taller truck version if anybody is interested. The car version base is easier to fit with a bench seat but I managed to get my truck version in by mounting the base backwards to avoid trimming
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-15-2009, 03:08 PM | #21 |
Enjoying left field
I had an 81 stepside years ago, and a installed a B&M Quicksilver into the seat right next to me. In park the shifter ball was right on the edge of the seat, and in drive it was right in the middle about 4" high, right where your hand rests comfortably. It was surprisingly easy to do, and it worked great. Sorry I don't have any pics, the truck was stolen 10 years ago. I'm planning on doing this again in my 70.
03-15-2009, 08:40 PM | #22 |
here's my shifter mount that also holds my procube delay box.
sorry I don't have a better installed pic
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-18-2009, 05:24 AM | #23 |
damn kevin, you drive one hellavu truck. i wonder whats it like.... and what it takes... thanks, that video there is some inspiration.
10-28-2009, 08:06 PM | #24 |
I made a stand out of a 3" exhaust pipe 45* bend to mount my pro stick on. I stole the idea from a 54 that was in classic trucks a couple of years ago.
1952 3100 5-window, work in progress 1985 C10, 454/th400 |
10-28-2009, 10:06 PM | #25 |
That's pretty Sexy!
