11-24-2020, 11:32 PM | #1 |
Clutch install question - X mark
I don’t remember an X mark on my clutch or flywheel. Do you guys know how critical this is? I’m thinking this could be the noise I am hearing on acceleration.
1963 C20, small window, long bed 292, 4-speed |
11-25-2020, 12:21 PM | #2 |
Who Changed This?
Re: Clutch install question - X mark
OK, I will confess that I never read the manual when replacing a clutch, so I never knew about the "X". I've replaced dozens of clutches in vehicles built from the '50s through the '80s and never had a problem, except for once on my Camaro I put the disc in backwards. That was fun, doing the job all over again. Maybe someone will have an answer, though. Since the clutch is engaged when you are accelerating, I doubt that that is the cause of the noise.
11-25-2020, 12:26 PM | #3 | |
I’m wondering if it makes a difference installing it with the dowel holes not aligned. From what I recall, there were three dowel holes on the flywheel that matched up on the crankshaft.
11-25-2020, 05:55 PM | #4 |
Who Changed This?
No, I installed the clutch disc backwards. It'll go together, but the clutch won't work. I've never installed a flywheel backwards.
11-25-2020, 07:06 PM | #5 |
The clutch disc that was in the truck could not be installed backwards - the springs protruded from one side more than the other. There's no way it could be bolted up like that.
11-26-2020, 01:53 PM | #6 |
I hate to say it, but it may be time to pull the tranny and get a good look around in there. I believe you mentioned the old pilot bushing was reused. That, along with a worn front bearing in the tranny could be your problem.
11-26-2020, 02:14 PM | #7 |
Who Changed This?
You're talking about the pressure plate, here.
11-26-2020, 02:39 PM | #8 |
Another question...
The auto parts online show 11 and 12” clutches. Mine is 11”. Will a 12” clutch work in mine? Or, will the mounting bolts for the pressure plate be a larger diameter?
11-26-2020, 05:53 PM | #9 |
BTW you can, I can and Steve can install the disc backwards. And a hundred more people have done it.
As the pressure plate is tightened the contact disc just pushes inward and the fingers flatten out. You don’t need a 12 inch. You do need a 168 tooth flywheel for a 12 inch though. |
11-26-2020, 07:37 PM | #10 | |
Not trying to argue... I think I get what you guys are saying. Either way, I am picking up a new clutch set tomorrow. Hopefully it will work better. Also, what are the dowel pins for on the pressure plate? There’s no holes in the flywheel for these.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 11-26-2020 at 07:47 PM. |
11-26-2020, 07:50 PM | #11 | |
Are the holes a larger diameter? Why do they make 11 AND 12 inch clutches?
11-26-2020, 09:39 PM | #12 |
Who Changed This?
They put that little 6 in front of much larger trucks; 12" is heavy duty. My Camaro, I could put the disc in either way, and I made a wrong guess the first time I did it. I used to race it, and usually only got 15k to 20k miles out of a clutch.
11-27-2020, 11:06 PM | #13 |
Another issue with this type of setup is the bellhousing to flywheel alignment.
There is some info at this site. https://www.novak-adapt.com/knowledge/clutches-etc/ Last edited by Desert dog; 11-27-2020 at 11:34 PM. |
