Dual gas tanks vortec swap question?
Hello, I have dual tanks that I would like to keep but spending 270 per tank for a sending unit is expensive. Does any one have any options? I bought a 2002 avalanche for 500$ with all its parts but the front bumper that hit a pole. Any help would be great.
Next project: 1970 K10
Re: Dual gas tanks vortec swap question?
Sending units from www.rockauto.com cost about (last time I looked) $94 for the drivers side and $101 for the passenger side.
Fuel pumps (EP381) from getgmparts.com are about $70 each. And the high pressure switching valve from JC Whitney is $83.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
thanks. So i need two sending units two fuel pumps and one high pressure sending unit?
#4 | |
Otherwise, yes. Sending units from an 87 for each tank, new high psi pumps for each tank, and the high psi valve. Of course, you will also need fuel injection (FI) rated hose for both feed and return, FI rated hose clamps, and if you have a returnless fuel rail, you will need a 99 Vette fuel pressure regulator/fuel filter and the related fittings for that, and the dash switch (for the switching vales) from an 87 as well as the harness from the switch to the valve. Or you can make your own harness.
#5 | |
![]() Last edited by foamypirate; 09-20-2010 at 02:09 PM. |
