07-28-2023, 06:40 PM | #1 |
Adding hyper spark dist
Where you guys mounting the sniper coil on your c10?
07-28-2023, 07:46 PM | #2 |
Re: Adding hyper spark dist
I went with the canister style of Sniper coil so I could mount it in the stock location.
https://www.summitracing.com/parts/SNE-556-153 |
07-29-2023, 12:30 PM | #3 |
Beautiful workmanship PJ !
71 C-20 07 Magnum RT AWD |
07-29-2023, 07:27 PM | #4 |
07-29-2023, 05:14 PM | #5 | |
Do these hyper spark coils work with non-mechanical Tachs? I've heard the PerTronix Ignitor III [a multi-sparking type] won't work with electronic Tachs.
07-29-2023, 07:30 PM | #6 |
I'm not sure. My OE style reproduction tach is connected to a signal that is generated by the Sniper TBI unit. The only thing I'm aware of that makes this coil different from a stock coil is that it can be connected to full 12V without the need for a ballast resistor or a resistive ignition wire.
07-29-2023, 08:06 PM | #7 | |
That's not the issue... My buddy Dennis put a P/III on the 427 in his '72 F250. His Tach went screwy. The PerTronix tech rep on the phone told him to get a P/II if he really wanted a Tach.
07-30-2023, 09:13 AM | #8 |
The ballast is there to protect the points not the coil. Do away with the points do away with the ballast.
07-30-2023, 08:02 PM | #9 |
Ballast Resistor is redundant with the GM OEM Resistor wire. Neither are to be used with any electronic ignition.
