![]() Join Date: Jul 2012
1962 GMC 4x4 Front Axle with disk brakes.
I've searched this forum and have seen most recommend swapping the entire front axle to something 73 and later if wanting disk brakes. I don't wish to do that, but the latest project I'm working on has had some "upgrades" to it already. Its the original closed knuckle set up, but PO had somebody put disk brakes on it. The disk brakes appear to be off an early Dana disk set up. I've read a few articles already about the differences in u-joint size, spindle length, and outer axle stub length....So here is my issue. Brakes work fine. But the knuckle seals need attention. So i started pulling everything apart. First thing i noticed when taking of the locking hub is that the axle stub doesn't protrude out past the locking hub insert to allow for the small snap-ring to be put on. Next thing is, the axle has literally no end play at all inside the spindle. I am used to these things having some end play with the outer axle snap ring installed. Anyway, I continued disassembly and once I go to the spindle and backing plate bolts off...the outer axle stub is "stuck" inside the spindle. It rotates freely, but I can't get it off. I don't see any form of retention clips of any sort. Here are some pics so you can see what I'm talking about. I sort of have a feeling the spindles and backing plates were swapped as they will "bolt on"...however I don't think the axles are the correct length. I read an article and it clearly showed the axle stups for a factory disk brake set up a a smidge longer than those that were factory drum brakes. Any tips or ideas would be helpful. I'm not opposed to the disk brakes at all...but I also want to un-frankenstien this thing so its the way it "should" be. Thanks in advance. I put the picture of the backing plate on so maybe hopefully somebody will know about what year these things came off of. The PO said "70 something".
Re: 1962 GMC 4x4 Front Axle with disk brakes.
I wanted to explain the "stuck" spindle thing a little better and include the link to the article for the disk brake swap. When i unbolt the backing plate and spindle from the knuckle...the spindle pulls the whole axle out of the housing...but the axle spins freely inside the spindle...not sure whats going on. I looked at the back of the spindle and I don't see anything holding it in there. I wanted to ask before I try to start separating anything with some "force".
http://www.4wheeloffroad.com/techart.../photo_06.html |
Here is a picture of what happens when I pull the spindle off the knuckle...the whole axle comes with it..and I can't really pull them apart.
No takers on this one I guess?
Sounds like it might be a press fit, but I've never worked on a closed knuckle front end before.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
I don't see how that spindle can be attached to the axle stub that way. Is there any play there? I had my closed knuckle apart not too long ago, and nothing unusual like this. The picture kind of looks like the spindle has a weld on it? I'm stumped too.
Yeah, I've not seen it before either. The "weld bead" you're probably seeing is some grime that has been since cleaned off. I'm going to go ahead and get the axle out and see about getting then separated. Its just so strange how the axle can spin in there with no problems but be stuck in there at the same time. Talking to John at RandP 4WD, he seems to think possibly the bushing/bearing might have a groove of some sort thats catching but doesn't think it will be a big deal to get it appart.
I agree with you in that I like the original closed knuckle axles. A lot of people don't. I see posts from time to time here where people are swapping them out, so keep an eye out and maybe you will come across one. Also, I think they may have been used in other trucks of that era, check eBay and craigslist as well.
I think you have a good idea as to how to fix up that scored knuckle. Even so, they are prone to leaks. Back in 2009, when I rebuilt mine, I packed all the associated bearings like conventional wheel bearings that you would find in a typical open knuckle. I don't put any oil in the knuckle, I just occasionally wet down the wiper seal. So far, so good. When I took the knuckle apart, the wheel bearings were very dry, and the knuckle bearings were destroyed from lack of lubrication. The grease won't run out like the oil. Something to think about when you get there. Good luck, and thanks for the pictures. Posted via Mobile Device |
I agree maxwoof. I just think its kinda nice to see them once and a while when they have the original equipment under them. I am still looking for parts, but leads are slim at this point. It seems like everybody that I have called has recently scrapped what they had. I do have a lead on 2 parts truck that may have some items of use. I don't disagree with the open knuckles being better, but this truck is almost 100% original, so I'm gonna try to keep it that way if possible. I've done the same trick you've talked about with the closed knuckles on my Willys wagon. There is special lube that is supposed to go in them...its really heavy, but still fluid. NOVAK sells the stuff. Its supposed to be heavy enough to the point where it won't leak out, but liquid enough where it still slings to lube the trunion bearings and u-joint. When I did my willys, I just put a bead of grease on the inside of the felt seal when I put it togther and made sure the u-joints were greased really well before I installed the axles. I used a needle fitting to make sure they were nice and full. That vehicle doen't go over 10 MPH when in 4x4, so I don't think it will sling out. I also packed the trunion bearings just like I would with a wheel bearing. I think it will work. So far it has. Thanks for passing on the tip though. I appreciate it very much.
I did find some extra outer axle stubs from R&P 4WD out of a ford and they are going to mill down the spindle bushing/bearing race as discussed in previous post so they will be compatible with the disk break spindles. I didn't want to cut the original axles and want to have them set aside when I do come across some hubs/drums/spindles etc. Here are some pics of the axle bell/ball repair. Its JB Weld original formula metal epoxy. Takes time to cure, but it works pretty well. I pasted it in, let it dry, then started with 220 grit then on to 320 grit. I had to apply a bit more in a few spots, but so far so good. Once its painted, there will be a nice smooth surface for the seal to slide on.
1960 GMC K1500 LB Fleet Side 1962 GMC K1000 LB Step Side 1988 Chevrolet C2500 |
![]() Join Date: Mar 2003
If you are interested, post your email and I will send you a copy of the Dana Spicer Maintenance Manual that contains the closed knuckle axle.
I think I might have them already. Does it say Spice Axle on the cover, and say model 44 on it with the "44" being really huge?
Send me what you have anyway. JPBrecheisens@aol.com Here is how my closed knuckles should look when they're all done. This is the work I did on my Willys about 2 years ago. I don't have the "spicer joint" tags on this one though. Maybe I can find some eventually. I think most repair shops tossed them out when they did seal work. This is a model 25 axle with the lockheed style drum brakes which is what belongs on the axle under this 62 GMC.
#13 | |
Got the manuals. I only had 1 of the 4 you sent. I'm sure they'll prove helpful in the future. Thanks for sending those my way. Alawys good to have info on these things. Jonathon
![]() Join Date: Sep 2011
JP, I'm sorry I couldn't help you out with my old 63 axle. TAlk about a day or 2 late.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
#15 | |
No worries. It happens. Jonathon
#16 |
![]() Join Date: Aug 2008
Dude, I would have given you the entire closed knuckle dana44 that i pulled out of my 66. But no one wanted it so it went to the scrapper...
![]() I think at this point you should use what you've got and get a few things machined to fit correctly where necessary. Then just maintain it and it will last as long as you do! And you'll be the only one on the block with a disk brake closed knuckle front axle!
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#17 | |
I am still looking for original parts, but in the mean time, I'm having a set of extra outer axle stubs machined down so they will fit inside the I.D. of the inner spindle bearing. After that is completed, most every thing should fit and work pretty decent. Once I get the stubs arrive, I'll post pictures etc so anybody that is interested can follow along. I'm out of town this week, so I've not had a chance to get it started. This truck is so close to original, I'm trying to keep it that way, but as long as it works (correctly) is all that matters. Jonathon
#18 |
![]() Join Date: Mar 2002
I have an original 63 front end. Send me a private message with your phone number.
Erl
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
#19 | |
#20 |
gotta love the connections that you make on this board... tons of information and helpful friends...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#21 |
Agreed. Its nice to be a part of group of folks that all have a common interest. I'm still new to the forum, but so far I like it and its been a positive thing.
#22 |
For those that are watching:
I got the ball repair done, and got some paint on it. The pics are not the best, but it turned out pretty well. Its humid right now so the paint is still drying, but should make a nice smooth surface for the new knuckle seals to ride on. I picked up a cheap dig camera today, so hopefully I can post better quality pictures instead of using my beat up old phone.
#23 |
Here is a better picture so you can see the repair. I posted the "before" picture as well so you can reference the improvement.
#24 |
ON stovebolt in the e-bay and craiglist finds there is a guy in california with a axle
#25 | |
Jonathon
