12-14-2004, 06:46 PM | #1 |
Just Don't Stop!
1/8 mile track times? best 60 foot?
Just couriuos how many of you guys are going to the track with your truck? I see alot more of the cruizer/custom show trucks on here. What's the best 1/8 or 1/4 ET and MPH? 60'?
What is your race weight and CID, tranny? Lets hear it. I'm running 7.7X's at 86 mph on the motor and 7.0X at 96 on the juice in the 1/8. With a best 60' of 1.94 (needs gears BAD).
1968 C10 build in process TT LSA/6L90e/9" |
12-14-2004, 07:25 PM | #2 |
My best 1/8 mile is 7.64@89mph with 150hp shot, best 60ft 1.72
383ci, TH350 w/2800 stall, 3.73 gear. It weigh's about 3900lbs with me in it. |
12-14-2004, 07:29 PM | #3 | |
The LuvShack Garage
WOW, MUST BE THE N20 9.53 1/8 AND 2.02 60FT - STOCK 400 SB, POWERGLIDE, 3:73 WELDED SPIDERS, 3650 ME IN IT.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
12-14-2004, 07:57 PM | #4 | |
It run's 8.60's @80mph without nitrous. |
12-14-2004, 07:28 PM | #5 |
7.7s motor , 6.8s on the squeeze. 3800 lb truck w/out me in it. 468 bb, ported oval ports , solid cam , vic jr , 1000 cfm holley , 373 gears, 3500 stall,and last but not least 200 shot. on pump gas .
every man must believe in something, i believe ill have another beer! |
12-14-2004, 08:30 PM | #6 |
Just Don't Stop!
383 Stroker - What size slicks/tires are you running?
12-14-2004, 09:10 PM | #7 | |
12-15-2004, 12:15 AM | #8 |
1/8 mile and 60' ET
8.52 @ 82 mph and 1.83 60', all throttle no bottle.
Kirk Myers 68 chevy swb owned since 87, under the knife 71 skylark 9.20's @ 76mph 1/8 mile |
12-15-2004, 12:40 AM | #9 |
ALRIGHT JIM!!! You got it into the TENS. Awesome!
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside |
12-14-2004, 08:58 PM | #10 |
6.97 @ 98mph with a 1.51 60 foot time 10.96 @ 121mph 1/4 thats a 406 weighing 3900 with driver and a 150 shot
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
12-15-2004, 01:01 AM | #11 |
Best 1/4 ET @ mph: 13.554@97.01
Best 1/8 ET @ mph: 8.567@80.29 Best 60 ft: 1.898 on MT Sportsmans Engine: 350 (zz4 clone) Transmission: Turbo 350 71 SWB FLEET 28.5 x 12.5 Mt Sportsman pro's
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
12-15-2004, 04:14 AM | #12 |
Just Don't Stop!
Bigjimz - what tire, gears, tranny are you running? I'm hoping to break into the 6's after a gear swap, my mile per hour is there just not the 60'...
12-15-2004, 09:25 AM | #13 |
the tires are 28x13.5-15 Mickey thompson ET Streets. 4.56 gears and a th350 with 4700 stall. Im putting a th400 with a trans brake in this winter. Im also going to a one piece drive shaft(with a LWB its not easy) I moved the engine back to the 6 cylinder location and im using a th400 long tail tranny and the shaft will still be around 63 inches long.
12-15-2004, 01:20 PM | #14 |
some fast ass hay haulers on here!
12-15-2004, 01:40 PM | #15 |
Just Don't Stop!
I had a one piece aluminum made a while back when I was still a LWB and it was 66" !!!
Course I grenaded that recently even though it was .125" tubing 3.5"...
12-15-2004, 02:07 PM | #16 |
14.1 @ 96MPH
With the old engine/tranny I was running 10's...in the eigth 2.2-2.3 60' times, of course I have an open 3.73 and regular radials. 15.7 quarters at 86MPH, but that was with an engine with a pretty choked up exhaust (behind the headers, that is) and a transmission that wouldn't shift 1-2 higher than 4200RPM.
With the LS1 (which is going in more or less stock, just with a much freer-flowing intake and exhaust than the F-Body it came out of) I hope to hit low 14's and 98+MPH in the quarter.
Project1970 - LS1 Swap Complete! |
12-15-2004, 02:50 PM | #17 |
Got Big Block?
first gen, quick truck! Cool videos at your site. Looks like you've been beatin' on that thing!
"Experience is what you get when you didn't get what you wanted." |
12-15-2004, 07:23 PM | #18 | |
12-15-2004, 04:37 PM | #19 |
Just Don't Stop!
I build it to drive it, and I drive it like I stole it!
12-15-2004, 06:58 PM | #20 |
I'll have times soon. I plan on going to the Creek to race my cousin and a couple of buddies. My cousin has a new HEMI pick up. I'm gonna kick his a$$!!! He doesn't know it yet, but I gotta bottle to go with my 350HO waitn' for him. Oh, and can't forget the drag radials Heh Heh Heh
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
12-15-2004, 07:43 PM | #21 |
Got Big Block?
sorry 383, those were your videos, not FirstGen's....
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 12-15-2004 at 09:58 PM. |
12-15-2004, 09:49 PM | #22 | |
12-15-2004, 10:50 PM | #23 |
best 60' is 1.7, usually get 1.8's eigth mile is 7.8 @90 mph, best 1/4 mile is 12.2 @111mph. 406 small block, muncie 4 speed, 4.88 gears. ALL MOTOR.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
12-15-2004, 11:04 PM | #24 |
fast dev what kind of shifter do you have? My uncle's 66 gmc has a muncie and its 2 miles from 1st to 2nd!
Thanks Kevin
12-17-2004, 12:25 AM | #25 |
hurst v-gate, short throw, inline shifter. less chance of missin' gears and bouncing off the rev limiter. Dev.
