12-09-2013, 07:56 PM | #1 |
600 to 770
I'm getting ready to add a break booster to my 72. The problem i'm having is I need a place to hook the vacuum hose from the brake booster. My question is I'm currently running a Holley 600 Carb with no place to hook my vacuum hose to, plus the carb needs a rebuild terrible on idle. I have a new in box 770street avenger that I bought a couple of years ago to go on the crate 350 with vortec heads I'm building. I'm currently running a stock 350. The 770 has plenty of vacuum ports for my brake booster, and will cure my idle issue,plus save on a rebuild. Do you think this carb will be to much for this stock engine or can I get by with it for a while? Thanks alot for any guidance.
72 GMC 1/2 Ton |
12-09-2013, 08:08 PM | #2 |
Re: 600 to 770
Being that you already have it I would run it. Vacuum secondary carbs are pretty forgiving. I wouldn't worry. You might lose a tiny bit of low end power but if your current carb is worn out it will probably run better. No worries drop it on and go.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-09-2013, 08:23 PM | #3 |
Re: 600 to 770
Thanks cableguy. That makes me feel better, plus save me a few coins.
72 GMC 1/2 Ton |
