![]() Join Date: Aug 2008
In most of the threads I've seen on here where someone is cutting their bed down from long to short they all seem to be using a small square type of clamp that holds both bed pieces together. What is this clamp and where would I find them? I am planing on cutting my bed down in the future and would like to have all the needed hardware in advance. Any info. would be great, thanks Shawn
Car Knocker
Re: Bed cutting question.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
harbor frieght has same as eastwood at fraction of the price//called buttwelding clamps
Reading the term "buttwelding clamps" immediately transported me to those days where my buddies and I would watch Beavis and Butthead and drink bear all day long and still not get enough of either.
low n' slo
![]() Join Date: Mar 2009
lol, that does sound funny. i was wondering the same thing on the name of these. do they work better than cleco pins?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#6 | |
Under Construction
x2 on harbor freight, i bought mine there as well....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 10-28-2009 at 11:03 PM. |
low n' slo
what i pictured were cleco pins, right? i was wondering if they were better than the buttwelding clamps..
#8 | |
Kevin LFD Inc. |
![]() Join Date: Feb 2008
Kevin,
When you are cutting down a bed floor, do you weld the top or bottom side or both? How much time would you estimate it takes to weld the bed floor and grind it. I know you are a lot faster than most but in talking to a local welder, he had no idea how long it would take and would only give me an estimate of time and materials. Thanks. Joel |
