06-12-2012, 10:03 PM | #1 |
Who sells good rear cab supports?
My truck needs rear cab supports, I want the best fitting ones I can buy, who sells the good ones?
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
06-13-2012, 03:22 AM | #2 |
1961 crewcab
Re: Who sells good rear cab supports?
just realized you need the rust patch panel that is welded to the cab? that I do not know...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-13-2012, 08:37 AM | #3 |
Being as i just installed 2 in mine , I can not recomend any of the ones I used .. one I cut in 2 and installed it in pcs. the other I got to go in in 1 pc. but did some creative reforming ,welding it just around the perimeter after hammering the edges so they contacted base metal...
06-13-2012, 09:09 AM | #4 |
Yeah mine fit like crap too. You would almost be better off making your own out of flat sheet to be honest
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
06-13-2012, 10:50 AM | #5 |
It's Better With Nitro
Just before I coated the bottom side of my cab, I ended up fabricating the rear braces from left over .032 sheet steel. I cut out the braces and used them as templates.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
06-13-2012, 06:48 PM | #6 |
I ended up ordering a pair from top banana, at $10 each I figured what the hell, I'll post up my thoughts when they show up.
