11-08-2014, 10:27 PM | #1 |
85 C4 Suspension on 1950 Frame
I have a 1950 frame that I'm going to box in. But I was wondering if anyone here has used the early C4 suspension on the original frame. If so did you build build the front cradle and all the brackets for the front and rear? I have seen where you can buy all of that from Flat Out Engineering for like $1600. Thanks
11-09-2014, 07:19 AM | #2 | |
Re: 85 C4 Suspension on 1950 Frame
Here is his thread. http://67-72chevytrucks.com/vboard/s...d.php?t=606275 |
11-09-2014, 02:07 PM | #3 | |
11-09-2014, 08:53 AM | #4 |
I built my rear brackets for my 50, I spent $52 for the steel plates and did all the milling at work after hours. Not really all that hard.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
11-09-2014, 02:08 PM | #5 |
11-09-2014, 09:39 PM | #6 |
11-11-2014, 10:57 PM | #7 |
So, I went the Flat-out route. (92 C4 parts) It is easy to install but there are a few things that are not said about the kit. The following is my opinion and some of the issues I had that I wish I had known before installing the kit. I did not have the body on the frame so I was at a disadvantage. I think most people want to center the wheels in the wheel well when they modify the suspension. You can move the front forward but it is not addressed in the instructions. You need to know how far forward you want to move the wheels to center them. Also the rear cannot be moved without modification to the kit. Research the wheelbase before buying the kit. There was an article in Classic or Custom Classic trucks in the past year or so that gives some details about the kit. I can tell you more if you want to PM me. Good Luck
