07-19-2009, 08:52 AM | #1 |
02 noise
I have started to notice a noise in the front end of my 2002 z71. It does it the most when I make a slight turn to the left (like on a curve in a street). I got under the truck and looked around did not see anything rubbing. The sound is hard to describe but sounds metallic, its not a constant but kind of like in waves.
Maybe half-shaft? Any ideas?
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily |
07-19-2009, 09:30 AM | #2 |
Re: 02 noise
Sounds likeba wheel bearingbto me
07-19-2009, 09:38 AM | #3 |
laying low
Re: 02 noise
How bout the disk brake pads? They have a wear indicator (schreecher for lack of a better description) that will touch the rotor when they get worn down close. At the early signs of wear they might only schreech when in a turn.
07-19-2009, 09:43 AM | #4 |
Re: 02 noise
Anyway to check out the hub assembly?
Hope its brake pads though.
07-19-2009, 09:54 AM | #5 |
laying low
Re: 02 noise
Put a jack under the control arm and raise the wheel off the ground then with one hand on the tire at 12 and one hand at 6 try rocking the wheel up and down. There shouldn't be any noticeable slack in it. Spin the wheel while up off the ground and see if it makes any noise that way. Pull the wheel off and inspect the brake pads. The schreecher is located on the bottom edge of the outside brake pad. It is probably very close to touching the rotor.
07-19-2009, 10:42 AM | #6 |
Re: 02 noise
Alright I'll check it out.
Thanks fellow arkansan
07-19-2009, 01:52 PM | #7 |
Re: 02 noise
could be brakes pads all i know is my 1991 escort make a metal grinding sound ever time i maded a right turn (curve) and it turned out to be the left front wheel bearing was bad had no play in it but i replaced the bearing and it went away
07-19-2009, 08:13 PM | #8 |
Re: 02 noise
I checked it out. Looks like its the bearing. Its sitting at the dealership. So much for truck parts for my project!
Thanks for the replies guys. Steve
