01-08-2024, 06:26 PM | #1 |
How does a pre-1972 SPID designate GMC or Chevy? SPID example for GMC?
This GMC decoder for a 70-71 GMC shows just five digits for a serial number.
The 67-72 decoder shows six digits. Is that the only indicator on a SPID that distinguishes a GMC from a Chevy in 1970-71? Edit, nope: The VINS differ in a number of ways. Thus real life example KE141Z654372 must be a Chevy? It's a SWB (model KE10734), I don't suppose many Chevy SWB K10 were built. FWW, the truck's build date is on the same day as my SWB C10, separated by <200 trucks, both serial and sequence numbers. K = 4WD E = V8 1 = 1/2 ton 4 = Pickup 1 = 1971 Z = Fremont 6 serial numbers
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-08-2024 at 08:18 PM. |
01-08-2024, 07:16 PM | #2 |
Re: How does a pre-1972 SPID designate GMC or Chevy? SPID example for GMC?
After studying the decoders a bit more, the difference GMC and Chevy is more than just 5 VS 6 serial numbers. For starts, a 1971 GMC has a 13 character VIN while a Chevy has 12 characters.
Real Life Examples: CE141Z654XXX C 2WD E V8 1 1/2 TON 4 PICK-UP 1 1971 Z FREEMONT 6 DIGITS SERIAL # KE141Z654XXX K 4WD E V8 1 1/2 TON 4 PICK-UP 1 1971 Z FREEMONT 6 DIGITS SERIAL # If the K truck was a 1971 GMC and all else equal, then the VIN would read: KE104?Z1XXXXX K 4WD E V8 1 1/2 TON 04 FENDER SIDE SPACE FOR DESIGNATION LIKE WHAT? Z FREEMONT 1 1971 5 DIGITS SERIAL NUMBER
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-08-2024, 07:25 PM | #3 |
I agree; it doesn't seem to be captured in the VIN until '72.
For a squarebody it's in the model code, ie: TK10903 = GMC, 4wd, 1/2 ton, lwb, reg cab pickup CC20943 = Chevrolet, 2wd, 3/4 ton, lwb, crew cab pickup. That does not seem to be the case for 67-71. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-08-2024, 07:36 PM | #4 | |
FWW, here's a 1972 GMC decoder to add, next to a 1972 Chevy. Both follow the same logic.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-08-2024 at 08:53 PM. |
01-08-2024, 11:16 PM | #5 |
67 gmc = "C" in the vin
68 gmc = "B" 69 gmc = "A" 70 gmc = "Z" In 71, it went factory code followed by "1"...S1, Z1, etc In 72, it went "2," plant code digit, "5"... 2S5, 2Z5 etc. Only gmc trucks had a "5" after plant code in 72. |
01-09-2024, 09:47 AM | #6 | ||
https://67-72chevytrucks.com/vboard/...d.php?t=570059 [EDIT - I see it now! Chevy and GMC denoted the model years in a different fashion!] [EDIT - That makes the following kind of moot, but I'll leave it in so my work is not wasted] Quote:
I agree with your assessment for '72. It would be model year ("2"), followed by plant code, followed by sequential portion of the VIN (the serial number), where: Chevrolet starts with 100001 GMC starts with 500001 Taking what you have pointed out and saying it differently, my summary would be: 67 GMC: (plant/year/serial) XC 1001 67 Chevy: (year/plant/serial) 7X 100001 68 GMC: (plant/year/serial) XB 10001 68 Chevy: (year/plant/serial) 8X 100001 69 GMC: (plant/year/serial) XA 10001 69 Chevy: (year/plant/serial) 9X 100001 70 GMC: (plant/year/serial) XZ 50001 70 Chevy: (year/plant/serial) 0X 100001 71 GMC: (plant/year/serial) X1 10001 71 Chevy: (year/plant/serial) 1X 100001 72 GMC: (year/plant/serial) 2X 500001 72 Chevy: (year/plant/serial) 2X 100001 That - is ridiculously nuanced. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-09-2024 at 10:34 AM. |
01-09-2024, 10:22 AM | #7 |
So - to answer the original question (that is, "How does a pre-1972 SPID designate GMC or Chevy?") the answer is it does, but it's clunky.
The '72 VIN format would be the first usage of the "modern" format, carried over into the squarebody era and (basically) still in use today. Additionally, the actual options appear on the SPID for a square, specifically: X88 = Chevrolet Nameplate Conversion Z88 = GMC Nameplate Conversion K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-09-2024 at 10:28 AM. |
01-09-2024, 10:53 AM | #8 | |
69 chevy: 9X8 71 chevy: 1X6 or 1F8 The patterns are easier to see in the build date project thread (posts 63-65). |
01-09-2024, 11:03 AM | #9 | |
So the generic decoder is not correct for 1969 Chevy (VINs start with 800001) or 1971 Chevy (VINs start with 600001 or 800001). Thank you - K Udated: 67 GMC: (plant/year/serial) XC 1001 67 Chevy: (year/plant/serial) 7X 100001 68 GMC: (plant/year/serial) XB 10001 68 Chevy: (year/plant/serial) 8X 100001 69 GMC: (plant/year/serial) XA 10001 69 Chevy: (year/plant/serial) 9X 800001 70 GMC: (plant/year/serial) XZ 50001 70 Chevy: (year/plant/serial) 0X 100001 71 GMC: (plant/year/serial) X1 10001 71 Chevy: (year/plant/serial) 1X 600001 or 1F 800001 72 GMC: (year/plant/serial) 2X 500001 72 Chevy: (year/plant/serial) 2X 100001
01-09-2024, 11:43 AM | #10 |
You guys seem to be discussing 70-71, but it just to be annoying: between 67-69 Canadian GMCs and American GMCs didn't have the same VIN convention.
The Oshawa plant put a "9" in the second field/space to denote GMC. My 67 "920" is K9247... etc.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
