Old 08-22-2004, 11:40 PM   #1
jhow66
jhow66's Avatar
3-speed & Dana to 350 turbo & 205
Got a 350 turbo & NP 205 located. Question-will this combo bolt up to my 72 Blazer crossmember and drive shafts that had the 3-speed -Dana combo? (out of a 1980 4X4 pickup.) Thanks in advance for any info.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-22-2004, 11:44 PM   #2
1969 GMC
1969 GMC's Avatar
do you still have the 3 speed and dana 20? that would help alot, unless someone that has that setup posts up. but shooting in the dark, I am going to assume the th350 is longer than the 3 speed, so you will probably have to relocate your crossmember back a few inches. if that is the case, then driveshaft work will need to be done also.
if not, then just disregard everything i said
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-23-2004, 12:20 AM   #3
jhow66
jhow66's Avatar
Don't have the new setup yet-still have the old setup. Wanted to see what problems I would run into. By the way, I notice that you seem to have a lot of knowledge on transfer cases by reading your posts. My son (orangeuavol) and I are building him a 72 Blazer 4X4. (our 1st 4X4) So feel free to gives us all the advice you can on the subject. LOL
Old 08-25-2004, 09:20 AM   #4
griesel72
griesel72's Avatar
[QUOTE=jhow66] By the way, I notice that you seem to have a lot of knowledge on transfer cases by reading your posts.
That is correct, Adam has helped me out with his Tech knowledge about everything 4X4 related
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 08-23-2004, 06:42 AM   #5
Blazer1970
Blazer1970's Avatar
I know that if you used a TH350/205 from an older truck ('69 - '74 or so), the driveshafts would work. The 1980 NP205 will have a slip yoke rear output, so you will need to come up with a new rear shaft. As for the crossmember, on the older 350/205 trying to use the Dana 20 crossmember will make the 205 hit the floor pan as the one for a 205 has about an inch more drop. I am not sure if the t-case adapter is the same on the 1980 version though. If it does hit, you should be able to space the crossmember down away from the frame a little if necessary.
Blazer1970 is offline   Reply With Quote
Old 08-24-2004, 10:19 PM   #6
orangeuavol
GO VOLS!
orangeuavol's Avatar
Have a shot at a TH400/NP205 combo, anyone know what years this combo came out in?
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 08-24-2004, 11:52 PM   #7
1969 GMC
1969 GMC's Avatar
It is from a K30, that is for sure. I believe that combo started in '80, but I could be wrong.
1969 GMC K2500
1996 Honda Accord
Old 08-25-2004, 12:25 PM   #8
jhow66
jhow66's Avatar
Sorry to bother you again but will we be able to use this in our 72 Blazer-crossmember?-sure that we will have to modify drive shafts?-any other catchs?
Old 08-25-2004, 04:33 PM   #9
1969 GMC
1969 GMC's Avatar
I am not sure if the stock crossmember will work or not. The adapter might be too large, and you would have to drop it down with some spacers, but maybe someone else can chip in here.
1969 GMC K2500
1996 Honda Accord
Old 09-01-2004, 11:11 AM   #10
us111
1969gmc
know this isn't about truck's but glanced over reading post and realized you live where i grew up in the 70"s..! cool.
us111 is offline   Reply With Quote
