05-11-2011, 08:00 PM | #1 |
Rear of truck not leval from left to right
My 1/2 ton SWB is lowered 4 1/2 (2 1/2 spindle & 2" coils) in front and 5 1/2" in rear with 4" drop coils and 1 1/2" lowering blocks. All springs are brand new. The truck sits approx 3/4" higher on the right (passenger side) than the left (drivers) side. It has the stock pan bar mounted in it's brackets and stock location. Could this be causing the issue? Do I need an adjustable pan bar to change the alignment of the rear. If so how do I do this. If I reduce the height of the passenger side lowering block by 3/4" and this levels the truck what issues am I creating if any. Thanks for you assistance.
05-11-2011, 08:18 PM | #2 |
Re: Rear of truck not leval from left to right
it is not unusual for a 40year old work type vehicle to have a tweaked frame just about every chevy truck i've had have been lower like that on the drivers side
05-11-2011, 08:29 PM | #3 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
05-11-2011, 08:50 PM | #4 |
So if I level it with by using different heights of the two lowering blocks I'll be okay and not cause or create any issues?
05-11-2011, 09:01 PM | #5 |
Moderator
I do not think it would cause an issue. I have contemplated doing it myself.
05-11-2011, 09:44 PM | #6 |
VA72C10
I'd try the panhard bar because with it 5 1/2" lower in the rear it's recommended anyways....
But I agree about the tweaked frame as a possibility...
Looking for a 67-72 swb or blazer project in or around VA. |
05-11-2011, 10:12 PM | #7 |
Moderator
With a 5.5 rear drop, you do need an adjustable panhard bar to re-center the axle. I do not think it will correct your height difference, but it is still needed.
05-11-2011, 10:56 PM | #8 |
unhook your panard bar and see how it sits with it unhooked.Also try swapping the springs from one side to the other to double check and make sure the springs are keeping the same spring rate and height under load.Even new sometimes one will still be weaker than the other.
05-11-2011, 11:13 PM | #9 | |
Moderator
05-11-2011, 10:59 PM | #10 |
my 71 swb is also a 1/2 inch lower on the drivers side. I have a 2/4 drop and have been driving for a few years with a 1/2 inch lowering block on passenger side to make it look right with no issues other than embarressment when people ask me why. My bed will be coming off pretty soon and the truck is going on the frame machine to measure and adjust. I cant wait and hope it comes out right. Also agree you need an adjustable track bar and try to have it mounted completely flat at ride height.
05-11-2011, 11:09 PM | #11 |
Thanks everyone for the input.
05-11-2011, 11:19 PM | #12 |
~Rest In Peace~
it levels out when the fat lady gets in
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
05-11-2011, 11:56 PM | #13 |
I was over 1/2" out on my 4/6 drop, turned out I had one of the springs in upside down. Switched it out and it leveled up.
Rex |
02-23-2024, 07:02 PM | #14 |
05-12-2011, 03:17 AM | #15 |
Laid Back
The front can be problem too if the front springs are not in the top perch right this can cause the back to be off
Posted via Mobile Device |
05-12-2011, 12:45 PM | #16 |
^^^^Check this close, My truck was over 1" off from side to side, turned out the sprint wasn't seated over the upper perch causing it to sit unlevel.
05-12-2011, 12:55 PM | #17 |
Registered Cruiser
If it was mine, I'd have the frame straightened. It does wonders for an old truck. It did for mine.
I intend to live forever. So far, so good. |
05-12-2011, 03:22 PM | #18 |
///Relaxed Atmosphere
smorg mine is the same just under 3/4 difference not sure why either but then again i didnt measure before i dropped it 6 inches and with the adj pan bar. the wheels are even from fender to fender and the front is the equal height it puzzles me also. but then again i had a 98 S-10 that was one inch off had to use different blocks to make it right.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
02-23-2024, 05:40 PM | #19 |
I just put new -2 inch lowering springs on the front of my c10 and the passenger side sits 1/2” - 3/4” lower than the drivers side. I have checked the frame and it is not tweaked. Any ideas? I am new to these trucks so I don’t know all the tricks and fixes for this. All help is appreciated.
02-23-2024, 07:01 PM | #20 | |
Totally ignoring everything previously posted, if I had the same problem you're having, I'd be checking the installation for properly installed and "seated" springs. If anything along these lines isn't found, try swapping the springs side to side.. If the low dimension remains the same side, you may have a tweaked frame or something going on in the rear. If the low dimension moves to the other side, you probably have one spring weaker than the other. On another note, when lowering the front, suspension and steering geometry have to be maintained. For the first 2 - 3 inches of lowering, dropped spindles are a much better choice over shorter springs. |
02-23-2024, 09:59 PM | #21 |
My RH rocker is 3/8+" taller than the LH. That or vise versa, I don't care. But for the life of me I can't figure out why. Body lines are correct, body is square, level front to back and side to side (2.5" & 4" drop). Even the cab floor is level or close, can't remember. Cushions torqued the same, and frames are equal. Hmm.... Can't tell from anywhere short putting a measuring stick on each side.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-23-2024 at 10:05 PM. |
02-24-2024, 10:42 AM | #22 |
That’s known as the “Chevrolet Gangsta Lean”
