07-23-2022, 04:02 PM | #1 |
What I did for a loud flasher
I went through a variety of flasher modules including ones that are supposedly loud, and concluded none are loud. I got tired of being one of those guys that drives down the road for 30 miles before realizing my turn signal is still on. So this is what I did. I bought a small solenoid from eBay, and cut the bottom inch off of a food can, and used a popsicle stick and construction adhesive to position the solenoid so it will hit the can bottom when energized. I turned in the sharp edge of the can and used pliers to crimp it down to make a smooth non-hazardous can edge. I cut a slot in the can and used a hose clamp to put it on my steering column. I wrapped a piece of solid 18 gauge wire to the bottom leg of my turn signal flasher for one of the solenoid connection wires, and connected the other wire to ground. It make a pleasant, crisp, and loud clack that I can hear over road noise, fairly loud radio, and engine.
07-23-2022, 04:32 PM | #2 |
Re: What I did for a loud flasher
My motorhome has a beeping alarm wired into the flasher circuit. It's incredibly annoying. Rather than removing it I put some electrical tape over it to quiet it. Your solution is very inventive. A beeper might be just the thing if you want audible evidence your turn signal is on.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-23-2022, 05:11 PM | #3 |
Very good work there.
It reminded me of a Musical one I had one time. It wasnt very loud though.
07-24-2022, 10:18 AM | #4 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
07-24-2022, 02:38 PM | #5 |
Excellent idea and write-up!
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
07-23-2022, 05:10 PM | #6 |
Sounds like a great idea, but I would like to offer one suggestion.
>> I turned in the sharp edge of the can and used pliers to crimp it down to make a smooth non-hazardous can edge.<< I would use what they call a "Smooth Edge Can Opener". No sharp edge and the removed top makes a perfectly reusable sealed lid. I use it for large canned dog food when only using 1/2 can. It seals well and doesn't stink up the refrigerator. I use it for tuna cans to be used for small parts cans and the lid holds remarkably well. I have used a tuna can for left over Por-15. I opened a can last week that had Por-15 for three years and it was still perfectly good. The Por-15 glues the already close fitting lid, so you have to very carefully tear the lid off with plyers.
'67 GMC 2500, 292, 4spd, AC |
07-23-2022, 07:15 PM | #7 |
Cool Stuff right there!
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
07-23-2022, 07:38 PM | #8 |
BlahBlahBlah
20 years from now long after you send this truck down the road a new to him truck owner is going to post a pic of this set up and ask if it’s stock lol
07-23-2022, 10:02 PM | #9 |
Many years ago an old man told me he always drove Dodge trucks because the blinkers were loud. Best reason to drive a Dodge I ever heard.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-24-2022, 02:40 PM | #10 |
And some smart aleck will say No, stock would be a Friskies tuna pate can.
07-23-2022, 11:39 PM | #11 |
Here in the Kalifornia Central Valley we normally have a lot of morning fog, so it's real easy to leave your lights on and return to a dead battery.
I tried several of the normal buzzer's that I simply couldn't hear. I finally ordered a good little siren that sounds like a European Police Car/Ambulance, makes the wife jump but not me, I'm deaf. A guy I know is a real wizard at Automotive wiring, he used a Volvo Relay, not sure of it's original intent, but now when I turn the ignition off, and the lights are on it let's me know. Works for me! |
07-24-2022, 02:45 AM | #12 |
I think I'd just use the original bimetalic flasher to run a relay that switched a beeper or whatever and the turn signals.
07-24-2022, 03:10 PM | #13 |
I would like the ebay number for that solenoid. I was lucky enough to find a couple of period correct headlight buzzers here on this site and it has saved me many times when on a mission at the home stores. My C10 has two batteries and two solenoids for starting. Long story of how it's hooked up but one battery runs the trailer brakes and other accessories but helps with the starting. An isolator charges them separately. I still love that little buzzer but I leave my signals on all the time. I am rebuilding my cluster and am thinking some super bright leds for the turn signals may be necessary. Or bigger incandescent bulbs but would have to change some things so that they did not melt. They flash anyway so I might be ok.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-24-2022, 06:26 PM | #14 |
jjzepplin, Here is the listing for the solenoid I used.
https://www.ebay.com/itm/123379006152 The bigger can the bigger the volume I think. I experimented with small pieces of metal and plastic for it to hit, and tried coffee cans, dog food cans, etc. It also makes different sounds depending on whether it hits near the edge or the middle of the can bottom, or somewhere in between. Steel seems to sound better than aluminum, to me. It would probably be practical to just rig it up on a bracket and make it hit the dash from somewhere on the bottom or inside. This is a little tiny solenoid, and a bigger beefier one would give you a significant clack. If I decide I want to turn it down, I'll probably switch to one of those little cans that ripe olives or mushrooms come in. I have heard a lot of things sold as buzzers but they are more of a beeping device and make a high frequency squeal or beep that is pretty much useless for a hard-of-hearing person because high frequencies are often the hardest to hear for somebody loosing their hearing. Those high frequency buzzers, and real buzzers that make a deeper buzzing sound, to me are both annoying. I didn't want to make something annoying, just something noticeable so I can tell the turn signal is on. |
07-25-2022, 07:44 AM | #15 |
Way to go, MacGyver!
