Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 07-13-2008, 12:34 AM   #1
cstm68
cstm68's Avatar
Aluminum polishing
how would i go about polishing aluminum so that it is shiny like billit aluminum or aluminum wheels.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 07-13-2008, 01:02 AM   #2
EdB
Re: Aluminum polishing
If the surface is smooth, you can polish it with almost any good
polish (Flitz, Never Dull, etc.) If it is not smooth, you will have to
work it down with progressively finer grits of sandpaper. Polish
it when after you get to, at least, 600 grit
After it is polished you will probably want to coat it. A trick I
have found is to wipe it with clean paper towels until there is
absolutely no black showing on the paper. Do not touch it
with your bare hands. You can then spray it with clear lacquer
or enamel. If you get "fish eyes" then you did not rub it enough
If it will be exposed to the elements,these coatings will not
last much longer than a year. POR makes a product, I think it
is called Pelqulid that is supposed to last a long time.
EdB
EdB is offline   Reply With Quote
Old 07-13-2008, 01:36 AM   #3
tk-mpl
tk-mpl's Avatar
After you polish it you can Zoop Seal it.. Heard it works well..
tk-mpl is offline   Reply With Quote
Old 07-13-2008, 02:24 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I tried one of those Mother's polishing balls on a set of wheels I picked up. The wheels were almost black from brake dust and grime. I power washed the wheels, used some Simple Green to clean off some of the crap and then spent about 10 minutes each with the ball.
Let me say, I was highly impressed. I could have spent a little more time on them but they shined up great. From a couple feet back they almost look like chrome. Up close you can still see a few spots of really bad brake dust. At some point I will hit them again with the polishing ball and really get them done up.
Worked great and fast, without a whole lot of effort.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-13-2008, 02:28 AM   #5
leddzepp
Moderator
leddzepp's Avatar
Harbor Freight sells a kit for use with an electric drill that includes several buffs and polishing wheels, with the 3 compounds you will need to bring out the shine. It sells for 20 bucks and works great.
Old 07-13-2008, 09:57 AM   #6
chevyboy55
chevyboy55's Avatar
Here's a link with a bunch of info about polishing.
http://www.caswellplating.com/buffs/buffman.htm
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 07-13-2008, 04:20 PM   #7
Riveted1
Tasty Cakes!
Riveted1's Avatar
Seen this stuff on Trucks, seemed to work awesome... Metal Armor
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 07-14-2008, 11:19 PM   #8
pooz911
pooz911's Avatar
I use Adams Polish #1 and #2 with a microfiber cloth on my aluminum wheels and it works great. I learned about this polish when I did some work with the owner of real rodders wheels.
www.realrodderswheels.com
www.cardomain.com/id/pooz911
pooz911 is offline   Reply With Quote
Old 07-15-2008, 08:24 AM   #9
Mudder
Mudder's Avatar
I moved this to detailing becasue thats where it shold be and there are other threads here on this subject. Once the wheels are polished, I use California Customs.. They do not advertise and can only be found online. Best and easiest I have used. I gave other stuff away that I had been using when I started using this.
Mudder is offline   Reply With Quote
Old 07-15-2008, 01:39 PM   #10
chris71
chris71's Avatar
i would stay away from zoop seal if you are near the coast, that stuff doesnt like salt, i did a pair of valve covers with it and went to the beach for a weekend, came back with them pitted from the salt in the air, just my experience
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 09-21-2008, 09:10 AM   #11
LONGHAIR
This is a vary general question, with a not so simple answer.
A lot of it depends upon the aluminum itself, it's not all the same. The better/higher quality heat treated stuff can be polished to a perfect shine that will last much longer than the soft stuff. Softer alloys will never polish up the same and what they will achieve will oxidize much faster.
LONGHAIR is offline   Reply With Quote
