05-22-2003, 01:33 PM | #1 |
Need rear bumper brackets 73-?
I've currently got a chrome cowboy bumper on my 74 & I'm going to swap it out w/a stock smooth bumper but before I can install it I need the inner & outer brackets. Anyone have some they can part with?
05-23-2003, 02:23 AM | #2 |
inner and outer? my rear bumper only had 2 rear bumper brackets.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
05-23-2003, 07:50 AM | #3 |
Well my 67/8 has 2-inner & 2-outer rear bumper brackets & when I went through a catalog it listed 2ea side as well. Since I don't have the bumpers yet I'm not 100% positive.
05-23-2003, 01:23 PM | #4 |
it might vary with bumper type, with my step (not step side) bumper there are just 2 thick brackets that extend the frame so the bumper can bolt to it.
05-23-2003, 02:32 PM | #5 |
Yep, that's pretty much what's under mine as well. They are 1/4" strap w/tabs for the bumper so I'm guessing they won't work w/an original style bumper.
05-25-2003, 09:51 AM | #6 |
Born Psycho
there are 4 brackets if you're going with the stock rear chrome bumper. i see them once in a while at our local yards but never pull them, they want too much for them.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-28-2003, 04:15 PM | #7 |
Does anyone know if Blazer brackets are different?
05-29-2003, 11:56 AM | #8 |
Oh,you can't buy that new
good luck finding them complete. there are also two seperate splash shields that go on the top for appearance. the Balzer has two that are the sameI believe the outers, and 2 are different. the splash shield is totally different. if you Email me at home I can look up the part numbers for you. I told the guy that i sold the last complete set to that he was getting a deal! (Tom) . the brackets alone are over $50 Ea . at LMC. DAVE
all4trux@snip.net
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
05-29-2003, 01:01 PM | #9 |
yeller
Man, I am going back to the JY and getting a bunch...there were at least 15 trucks with both front and rear bumpers!
I plan on going next month (it is 1.5 hrs away), if you still need them then i will pick some up. ...Jeff |
05-29-2003, 04:11 PM | #10 |
Under construction!
Wish I would have seen this post before. I threw mine away the other day.
2001 Silverado bagged on 22's. *Sold* |
05-29-2003, 06:56 PM | #11 |
Dohhhhh!!!!!!!!!!! Bagged C10 what were you thinking.
Well, while driving to Sears to get a new 'sawzall' yesterday, I spotted what looks like a 76-77 burb (piss yellow w/woodgrain inserts even) in my sub-division. It has a somewhat slightly mangled smooth rear, so I'm going to go back when I get my drop completed & show him my very nice, undented, aftermarket bumper & offer an 'even swap' & I'll even do the work (then I also get the rear carcuss I need for Captkaos)! I figure, as beat up as the burb is, they might just go for it.
05-29-2003, 11:09 PM | #12 |
I have rear brackets off a 79 blazer I will let go cheap. And a set off a 84 blazer
05-31-2003, 12:40 PM | #13 |
Drive it like U stole it
I have all you need $40.00 + shipping.
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
