Old 11-27-2019, 01:03 AM   #1
TxCajun
TxCajun's Avatar
66 C10 Hood Repair - large shallow depression at rear of hood
I'm doing rust and dent repair on the hood of my 66 C10. At the rear center area of the hood there is a large shallow depression. The picture below shows a straight edge laid on top of one of the ribs at the center of the hood.
a. I wanted to confirm that these ribs should be straight and flat, i.e. not have this depression.
b. Any suggestions on how to go about fixing this? Because it is such a large, unsupported area, it seems to want to "oil can" back to this position.
Thanks!
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 11-27-2019, 04:49 AM   #2
Mack B
Mack B's Avatar
Re: 66 C10 Hood Repair - large shallow depression at rear of hood
Thanks!
Here's a thread I started with that same situation. Only one of my ribs dipped down so I'm possitive the area should be flat. My answer was I found a different hood , but there is some good advice in the replys.
http://67-72chevytrucks.com/vboard/s...d.php?t=783590
Mack B is offline   Reply With Quote
Old 11-27-2019, 09:05 AM   #3
nsb29
nsb29's Avatar
You should Post this in the paint and body work along with more pictures
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 11-28-2019, 12:32 AM   #4
TxCajun
TxCajun's Avatar
Mack B --- thanks for the response and pointing me to those links, they were very helpful.
Regards,
