03-14-2023, 06:45 PM | #1 |
425hp409
Small Block engine Accessories needed
I am helping a friend rebuild a 70 C10 he just bought without an engine, It came with the AC comp and brackets, but nothing else. I have a long block that I am going to rebuild but need everything else. Hoping someone had an engine they pulled out to do a conversion and didn't need the items that I am needing.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
03-14-2023, 06:52 PM | #2 |
Re: Small Block engine Accessories needed
I have a power steering pump with brackets, the pulley is rusty and I believe it's off a 72. The brackets are different but still work.
03-14-2023, 09:09 PM | #3 |
It's a bit of a ride from Prosper but DFW has 4-5 picknpulls where you do just that. There you'll find mostly complete cars with the accessories still attached if they haven't been there long. This might be easier than piecing things together.
Check the recipient engine heads for bolt holes in the front vertical ends. |
03-14-2023, 09:50 PM | #4 |
There's also this place in Denton: CTC Auto Ranch
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
03-15-2023, 02:00 PM | #5 |
Sending you a PM. I may have everything you are looking for. Also, I am in Midlothian, so fairly close.
Chad |
03-15-2023, 07:18 PM | #6 |
Sorry, I was wrong. The motor I have has already been picked clean.
Chad |
