10-17-2008, 10:18 PM | #1 |
frame swap for a 4x4
I am told that a GMC 2wd frame can be converted to a 4x4 by using the front spring hangers from a K truck and a front crossmember????
Does anyone know for sure how this is done?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
10-17-2008, 10:44 PM | #2 |
its all about the +6 inches
Re: frame swap for a 4x4
I'll move this to the 4X4 section. They can probably tell you every little tidbit you need to know.
With that being said... I *THINK* it can be done, and probably takes what you listed, and then the 4X4 steering gear box and a few other odds and ends. Last edited by Longhorn Man; 10-17-2008 at 10:45 PM. |
10-17-2008, 11:21 PM | #3 |
yea, I posted around in frame and suspension and the 4x4 forum and here also hoping for attention.
does the steering box bolt to the 2wd frame without trouble?? I never thought there would be a difference. I have everything on my K truck to swap over. I straightened the frame as best I could but it still favors pulling slightly right, just enough that I know it and wish it didn't. For now the truck is used minimaly and only short distances. Someday I would like to swap.........................or find a shortbed frame!!!!!!!!
10-18-2008, 10:54 AM | #4 |
I know a guy that did just that. He told me that other than a few minor things it is basicly a bolt in, all the holes are already there. I didn't see the before but I did see the after and you'd never know it was a conversion. I've got my eye on a 71 Chev with rear leaf springs and if I can get my hands on it I will do a conversion to it.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made Last edited by sweet70beast; 10-18-2008 at 10:56 AM. |
10-18-2008, 11:22 PM | #5 |
Active Member
All the holes aren't there, but it's not hard to drill the ones that aren't. If the 2wd frame has rear leaf, you're a step ahead. One of the PITA things on my 68 was flattening out the dimples in the front where the e-brake cables go through. The other was that the 2wd rear end spring hangers are shorter and it took a 4" block to make it sit level with the stock 4X4 front springs.
The 4X4 power steering box bolted right up on mine.
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
10-22-2008, 04:13 PM | #6 |
and is there any difference in the 3/4 ton to the 1/2 ton frames in consi9dering this swap????
10-22-2008, 06:35 PM | #7 |
6>8 Plugless........
Like mentioned all the holes are not there. Mainly for the shackle mount for the front spring. I am in the process of doing this to my 72 longhorn. When i get it far enough I will post up pics and info. I am planning on cutting the part of the frame where the e brake knotches are and installing a flat piece of steel there so it looks factory. I may even replace the rear spring hanger because I am using 6" lift springs in the front and if I don't replace that hanger, I will need a 10" block. LOL I think the biggest difference in the frames, is the 1/2 frame rail heighth is shorter than the 3/4. But I am not 100% on that.
10-24-2008, 10:51 AM | #8 | |
In House Collision Technician
MAXIMUM DESTRUCTION |
10-24-2008, 01:02 PM | #9 |
so 1/2 ton and 3/4 ton frames were the same dimensions and material strength?
10-24-2008, 02:36 PM | #10 |
I'm a poor spectator
Interesting thread, I have a 69 chevy parts truck with rear springs, might have a new project after all.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
10-24-2008, 04:05 PM | #11 |
as far as i know, the 1/2 & 3/4 trucks, blazers, & suburbans use the same thickness in the steel. 1 tons are thicker & as i said before, depending on their intended use, some had a physically taller rail. however, i don't remember the time span when gm changed the steel in their frames. i believe late 70's or early 80's.? maybe someone else here can pinpoint that for u.
10-24-2008, 05:07 PM | #12 |
okay, I have located a 1/2 ton longbed frame from a chevy with the rear leafs. The guy thinks that the 1/2 ton might have a slightly narrower, like 1 inch per side or so, set up in the rear spring hangers or the rails themselves, than the 3/4 tons?????
I guess the problem is putting the 3/4 axles under the 1/2 ton frames in the rear. anyone know anything about this fact???
10-22-2008, 06:36 PM | #13 |
And another thing, you will need the bumper brackets from the 4wd truck in the front because 2wd and 4wd are different.
10-28-2008, 03:13 PM | #14 |
Packrat
I thought the bracket difference was because of the frame, and the bumpers were all the same?
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
10-28-2008, 11:48 PM | #15 |
The bumpers are the same. But, the 2wd brackets go behind the rad support on the frame and on the 4wd they bolt right into the pocket of the rad support mount at the frame.
10-24-2008, 05:48 PM | #16 |
I am going to measure this blazer 4x4 frame I have and the longhorn frame I have to compare. I never have done it, the 3/4 tons just look bigger in the frame area I guess?
10-24-2008, 06:11 PM | #17 |
measuring your blazer frame and your longhorn frame is going to tell you what?
I do have a suburban 2 x 4 frame and my panel 4 x4 frame and the 4 x 4 is 1" deeper. mine are same year , same w/b ron |
10-24-2008, 09:22 PM | #18 |
so what about the width at the rear spring hanger area????
10-25-2008, 01:34 AM | #19 | |
These measurements were taken from top to bottom of frame flanges. And both frames were 1/4" thick. The Bold is for the longhorn to try to see the difference in the post. 1972 Blazer 4x4 1/2 ton 1972 Chevy Longhorn 3/4 ton 2x4 6 1/8" tall behind front cab mount 7 5/8" tall behind front cab mount 1 1/2" difference 4 1/2" Tall above rear axle 5" Tall above rear axle 1" difference Rear Spring Hangers On Frame Front Front 10" 5 1/2" 4 1/2" difference Rear Rear 7 1/4" 7 1/4" Same So what this shows me is that the frames are different from 1/2 ton to 3/4 ton. Now this could be different with the 2wd coil spring rear suspension trucks. But not with the leaf spring 3/4 ton trucks. Basically the 2wd 3/4 ton frame I have is the same as a 4wd frame almost. Since some holes are different up front I realize they are different. But that shows a comparrison on frame heighth. And for the rear leaf spring hangers. I had it backwards. Everyone told me the rear hanger was longer on the 4wd's than the 2wd's. Well in reality it is the front hanger that is almost 4 1/2" longer than the 2wd one. That is a big difference. And the rear ones are the same. Last edited by Dieselwrencher; 10-25-2008 at 01:48 AM. Reason: Bold info to tell difference |
10-25-2008, 01:38 AM | #20 |
http://www.chuckschevytruckpages.com/framespecs.html
the "S" dimensions don't make any scence to me for longbed/shortbed trucks................??????????
10-25-2008, 02:36 AM | #21 | |
ron |
10-25-2008, 08:58 PM | #22 | |
10-24-2008, 09:41 PM | #23 |
don't know. best thing to do is find the chassis in question which is opposite what you have and measure it for yourself; then you know exactly what the differences for. you will get a variety of answers on these boards. always confirm what you need to know and that will alleviate any foreseeable problems
ron |
10-24-2008, 10:03 PM | #24 |
look for grendel he has done this and posted the whole build up. AWESOME work he's done. Good Luck
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT Last edited by manimal; 10-24-2008 at 10:04 PM. |
10-25-2008, 12:12 AM | #25 |
Active Member
Dang, sorry, it's for 73-87.......... thought I had another link for ours, but can't find it.
Check this link from Chuck's Chevy pages, it gives frame dimensions http://www.chuckschevytruckpages.com/framespecs.html
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". Last edited by GMCMAX; 10-25-2008 at 12:30 AM. Reason: Wrong info |
