01-25-2020, 08:12 PM | #1 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Looking to ID a Holley 6R-8026 4bbl "Carb Shop" carb
Cant seem to nail down exactly what this thing is, I'd like to verify the cfm? It has no choke and mechanical secondary's. I'm building a solid lifter 439ci (.060" over 427) BBC motor with a Clay Smith solid 304 cam, 258 duration @ .050" .615" lift. With a Weiand 7620 single plane intake. I'll post pics directly...Thanks,
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 01-25-2020 at 08:18 PM. Reason: adding pics |
01-25-2020, 09:00 PM | #2 |
Re: Looking to ID a Holley 6R-8026 4bbl "Carb Shop" carb
01-25-2020, 09:54 PM | #3 | |
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-25-2020, 10:02 PM | #4 |
60-66 Nut
You can also measure the diameter of the butterflies and get a good idea by comparing them to the size of specific known CFM carbs. I have a Holley book with all the butterfly sizes.
01-26-2020, 10:30 AM | #5 |
They're 1-11/16" diameter...I found Carb Shop's Facebook page and oddly enough they responded right back indicating that it is a 750 CFM carb. The carb has been on the shelf for years so I'll go through it and check the pump diaframs and jet sizes, etc. I don't think that cam will be making much vacuum so power valve rating will be a concern as well. This is my first Holley carb so everything is a learning experience. Any and all help is greatly appreciated, thanks! 👍🇺🇸
01-26-2020, 10:41 PM | #6 |
60-66 Nut
I looked in my Holley book and it seems that with the double pumpers, the 1-11/16" throttle bore is used from 650cfm thru 800cfm. The flow difference is determined by the venturi diameter. A 750 should have a venturi diameter of 1-3/8".
01-30-2020, 03:26 PM | #7 |
Captain Fab, what holley book do you have that has that info? Looking for a way to ID 850 CFM carbs, as I need one and it seems no one near me know actually what they have and most can't read the #'s
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
01-30-2020, 10:44 PM | #8 |
60-66 Nut
It is the Holley performance catalog from 1998. I have had Holley catalogs prior to this one that had the same info. There is a section towards the rear of the catalog that has all the carb list #'s and all the specs for each one.
01-31-2020, 07:41 AM | #9 |
interesting, thanks.
