64 front brake drum removal
I know somewhere on this site this question has been answered, but I can't find it. I've got a 64 1/2t with drum brakes. I removed the rear drums with much effort, using a homemade puller and 1/2 a days work. I want to look at the front brakes and i am having the same problem with the front drums. My manuals don't say anything about the drums being riveted on, but these drums have 3 round head rivets on them. Does this indicate the drum is riveted on and need to be drilled out, or are these just buttons on the surface of the drum? Thanks, Roy
1948 Chevy 1/2T 1964 Chevy 1/2T stepside short bed 1939 Pontiac coupe Street Rod 2005 GMC 1/2T short bed |
Re: 64 front brake drum removal
It would be easier to take the hub and drum off as one unit. If your going to replace the drum you can grind off the rivets and install the new one. If your just doing an inspection , then everything can go back on as one assembly.
Thanks. I'll do that. I wonder why the service manual just says take the drum off with no mention of the rivets?
