04-22-2004, 01:38 AM | #1 |
What gears in the rear-end??
I've got a 90 1/2T burb, 4WD, 350, 700r4 tranny. Anybody know what gears are in the front and rear end? All i know is that with the 35's on it now the thing is a dog!!!
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '19 Chevy CC 4x4 Duramax Dually |
04-25-2004, 07:27 PM | #2 |
ratios
Get the three letter code of the glovebox label that starts with the letter g . (ex . gu6 6t4 ,ect ) gu6 is 3.42 and gt4 is 4.10 . let me know what
it is and i can tell you. Also a g80 means posi. My 80 here is 4.10 and 35s and it pulls good. |
04-26-2004, 11:02 AM | #3 |
Cart before the horse.
Gears before tires ALWAYS. I would stop driving it till you get the gears done. 700r4 will not put up with that long. 35's with a 700 I would go with 4.56.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
04-26-2004, 09:39 PM | #4 |
My 80 is a turbo 400. It does make a differecne over a 700r4.
04-27-2004, 12:54 AM | #5 |
Well I looked up the number's in the glove box, it says GT4 G80, so I guess i have a 4.10 posi. Sure doesn't seem like it though, guess I'll have to pull the diff cover and verify it. Also- what rear-end/ front end is it? Is it a corporate 10-bolt???
Thanks for all the help. Steve
04-27-2004, 09:06 PM | #6 |
ratio
I am sorry steve but gt4 is 3.73. gt5 is 4.10.
05-03-2004, 04:19 PM | #7 | |
Land Beast
are you postive gt5 is 4.10???
90' GMC 1 Ton Suburban |
05-04-2004, 03:42 AM | #8 |
as i just finished both my front and rear axle now for the 3rd time--i am sure you have 373--in the axles with out anydoubt....if you are not on the highway's much--then listen to the advise given on the 456-gears....but if your like me and highway cruse thousands of miles-then go with the 410-411....this will give you tons of power--and you'll sh-t over the differance...from the 373's
but if in the future you plan on going to 38's at all- then go with the 456 now and save you time and bucks latter.....i really wish i had gone with the 456-instead of the 411---but the gas consumption is to much--if you do not need the 456 every day,,,,i run 36'' trxus---and still have enough power to eat these new big fords for breakfeast.... hope this helps aabear john |
05-15-2004, 01:14 AM | #9 |
I have 4.56s in my 90 3/4 ton with 285/75r-16 tires and am always pulling it out of 4th to get the rpms and the power up, but cruising down the freeway on the flats it likes 75mph with 16mpg.
04-27-2004, 09:08 PM | #10 |
no problem- i'll probably go to a 4.10 gear- that might help a bit! But it's still a pig...LOL
04-30-2004, 09:13 PM | #11 |
Big Block Blazer
I have a 12 Bolt with 3.08's and 32's...
Good thing the Big Block can make up for it till I get 3.42's. I don't know why I didn't put a diff. set in when I had the new 3.08's put in during the building of the new Rear End...
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys] |
