06-22-2004, 06:49 PM | #1 |
Saving 1 truck at a time!
Energy Suspension Body Kit
Anybody running the cab and core support mounts? They appear to be less expensive than the stock units.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
06-22-2004, 08:24 PM | #2 |
PROJECT 7DEUCE
I have the body mount's in poly on my blazer and would not run anything else just me 2 cent's worth...
06-22-2004, 11:03 PM | #3 |
Just Don't Stop!
where is a good place to buy those mounts?
1968 C10 build in process TT LSA/6L90e/9" |
06-22-2004, 11:12 PM | #4 |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-23-2004, 12:30 AM | #5 |
Thanks guys. That is all I need to hear about them. I am going to order some tonight. I guess it will be a couple more days before I can do the trial fit of the cab...I will have to wait for UPS...LOL!
06-23-2004, 04:45 AM | #6 |
user # 2756
I have the prothane ones on both my trucks. Bought them from JCWhitney. I recommend replacing your existing hardware also. The prothane kit comes w/ the rear bolt/nut.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
06-23-2004, 10:10 AM | #7 |
Project Junkie! Fishing Poor!!
Just a thought here. Urithane body mount kits take all the flexabillity out of these trucks that they were designed to have. These trucks do not have rigid frames, they are "C" channel frames designed to flex and bend acording to the terrain. This is why the frames are riveted and bolted together and not welded. Rivets and bolts alow for flexabillity and so do rubber body mounts. On the other hand, the cabs and individual body parts are welded together and can not withstand the flexing the chassis is designed to withstand. The rubber body mounts allow the frame to move indipendantly from the body, and also absorb vibrations from the road. The end result is going to be rattling cabs at best and bushings pulling through their mounts at worst. I would think long and hard befor I stick a set of the urithane mounts under one of my trucks. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-23-2004, 10:43 AM | #8 |
By the way, can anyone tell me the advantages urithane body mounts have, besides they may be a little cheaper? I hear that they may last a little longer. But either one of these advantages do not outweigh the disadvantages. Do they make the truck handle better? I don't think so because they are not suspention related. WES www.ClassicHeartbeat.com
06-23-2004, 10:55 AM | #9 |
And I'm not so sure they last longer either. I put urethane body mounts on my blue K20 and three of them have went bad in 10 years. The truck also doesn't flex. I noticed I have another one that is coming apart right now under the cab.
I agree with Wes, I put the stock rubber mounts on my latest green one. The original ones were 33 years old and still looked good. Just my two cents. |
06-23-2004, 07:21 PM | #10 | |
06-23-2004, 07:31 PM | #11 |
I also have Poly bushings on my truck, and I am happy with them. I do believe the ride to be a little stiffer, but not terrible. Wes, what you said does make sense though, but If the truck is more of a street truck, wouldn't you want a stiffer chassis? Isn't that why we put sway bars on? I too can see the benefit of rubber on an offroad truck, but on a street driven truck, what's the harm? I hope I'm not sounding like I'm attacking anyone, just trying to voice my opinion.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 06-23-2004 at 07:32 PM. Reason: can't type or spell apparently. |
06-23-2004, 08:05 PM | #12 |
I ordered mine from AutoZone. Looked up all the part numbers and pricing on line. Summit and others were cheaper on some but with the shipping costs AutoZone turned out to be cheaper. I just went into my local store..gave them the part numbers and picked up the parts within two days. No shipping.
Oh yeah....I got mine in all red and Summit and others didn't show these part numbers.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
06-23-2004, 08:30 PM | #13 |
crazy longhorn, I am just curiouse as to how poly body mount bushings help you launch straiter. Does the cab and radiator core support stiffin up the frame. I can understand how poly motor mounts would be help keep the engine from flexing, somehow changing the angles on your clutch linkage, but how do the body mount bushings help? jorgensensc, I don't think that you are attacking anyone. You are right urithane bushings would not harm a street truck nearly as bad as an off roader or heavy hauler. However, just because it is a street truck doesn't mean that it doesn't flex. There are speed bumps, ramps into stores, uneven road surfaces, uneven parking lots, and etc. A truck does lots of flexing wether or not it is on the road or off. WES www.ClassicHeartbeat.com
06-23-2004, 09:18 PM | #14 | |
06-23-2004, 10:27 PM | #15 |
It sounds like you stiffened your frame. In the instance where a frame does not flex, poly wouldn't do any harm because there isn't any independant movement between the chassis and body. WES www.ClassicHeartbeat.com
06-23-2004, 11:22 PM | #16 |
yes, the addition of the heavy cross sills on the box did effectively stiffen the frame(I think). the truck is much firmer to ride in, But not a complaint. if I jack up 1 corner, she still flexes somewhat, just not like factory. The old wood floor boxes IMO , had more flex than the steel floor versions. I still need a little help up front, but i think a good swaybar & bushings will help. I sure do agree that the stiffer cab bushings may not be for every build, just a matter of useage crazyL
