Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 08-25-2004, 02:54 PM   #1
Joe67
67 is sold
Rear Fuel Tank swap
I will be ordering a rear ruel tank/cell setup for my '67 SWB 2wd truck very soon.
I've been looking at the tank offered by Fuelcellguy as well as the kit through ECE (seems a bit pricey to me).
Another option is a stock GM repro blazer tank.
I'm looking for real world replies. What do you guys honestly recommend and why? What would you do if you had to do yours over again?
Consider I am going with a 6" drop or bags in the rear end.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline
Old 08-25-2004, 08:47 PM   #2
MACKL
Almost done!
MACKL's Avatar
Pick the one with the largest fill neck size. Otherwise, you spend a lot of time trying to fill up the tank. The 1 1/4 ID necks are too small. Next time I will cut the old one out and weld in a larger size. Kinda hard to weld once you put fuel in it. Even so, I would do the conversion again. I got a tank from Kenny's Truck in Tulsa OK. About $225 for the complete kit. I installed the marker light fuel filler and love it too. Good luck with the conversion.
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline
Old 08-25-2004, 10:47 PM   #3
ratrod67
ratrod67's Avatar
I like my Blazer tank but it hangs pretty low.
ratrod67 is offline
Old 10-21-2005, 01:57 PM   #4
BigMike
BigMike's Avatar
Re: Rear Fuel Tank swap
Where do I find more information about the side marker fill conversion??? I have tried searching for it but nothing comes up.
Mike
BigMike is offline
Old 10-21-2005, 06:36 PM   #5
matthufham
Mike
that's a beauty in your avatar!
http://67-72chevytrucks.com/vboard/s...699#post599699
stepsides will be this easy. fleetsides are trickier
go here for the fleetside install
http://www.classicheartbeat.com/mark...t_gas_door.htm
matthufham is offline
Old 10-21-2005, 11:49 PM   #6
BigMike
BigMike's Avatar
Thanks...Too bad it is only a 1/8 scale RC truck body that I custom painted (I do that as a hobby)
Mike
P.S. Thanks for the links...I had found the stepside version but not the fleetside.
BigMike is offline
Old 10-22-2005, 08:47 PM   #7
matthufham
too bad there's a driveshaft in front of the axle. they make saddle tanks to go on the sides. don't ask me where they're sold, because all the one's i've seen are originals.
@big mike
again here's a fleetside installation of the sidemarker filler.
Old 08-26-2004, 12:24 AM   #8
nate68
i just used a poly fuel cell (you can get htem from summit for pretty cheap)
68 short step, 406/700r4, 9" w/discs.
nate68 is offline
Old 08-26-2004, 07:22 AM   #9
Joe67
67 is sold
Thanks for the replies, good points.
Nate68 - any chance I could get a pic or two of your install? Did you have to fab your own fill neck? Do you fill in the bed floor or elsewhere?
Joe67 is offline
Old 08-26-2004, 03:17 PM   #10
nate68
here's an old pic from before the bed was on.
nate68 is offline
Old 09-02-2004, 05:42 PM   #11
Joe67
67 is sold
Anybody else have info to share?
Joe67 is offline
Old 09-02-2004, 05:48 PM   #12
dallas71
dallas71's Avatar
I have not done this yet, but I know that the Truck Shop has the complete setup for $166 and it includes all of the straps, sening unit, nuts and bolts....This is the best price that i have seen so far....I am just waiting for the pennies before upgrade....
dallas71 is offline
Old 09-02-2004, 09:20 PM   #13
Z28Owner
Z28Owner's Avatar
In my catalog it says that the straps and sending unit are sold separate. So that would be another $75 on top of the $165.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline
Old 09-02-2004, 09:37 PM   #14
71swb4x4
71swb4x4's Avatar
I have a FCG tank. I just fired my TPI up tonight, and so far the tank works great. It installed easy, and mine has an in-tank pump. It also has a 2" filler.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline
Old 09-02-2004, 10:50 PM   #15
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
71swb4x4 i think you can take the working on TPI off of your signature now
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline
Old 09-03-2004, 12:52 AM   #16
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Has anyone put a later style blazer tank in there 67-72 truck... Will it fit, it looks like it will fit in the frame... what are the dimensions of the 69-72 blazer tank, anyone know. Thanks
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline
Old 09-03-2004, 01:04 AM   #17
gonebad2
Merciless Butcher
gonebad2's Avatar
I used one from FCG. It was awesome. He included the mounting straps and builds it to your specs: location of filler etc.... I will use his tanks on any future projects. My ex-brother in law once used a plastic fuel cell from Summit. It was really flimsy and really didn't fit all that well. I just didn't like the idea of that flimsy plastic cell under my bed. That was the major reason I went with FCG.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline
Old 09-03-2004, 07:16 AM   #18
Joe67
67 is sold
Yeah, so far the FCG setup looks like just what I want.
I appreciate the feedback guys
Joe67 is offline
Old 09-03-2004, 10:49 AM   #19
Senator350
Senator350's Avatar
i was really thinking about a fuel cell. but i didn't want a gas tank under the bed. so at the risk of being completely origional, i'm installing a diamond plate combo tool box/tank. it is pretty normal for people with 5th wheels to have an aux tank like this. but i really like having the combination and having a 50 gallon capacity. looks attractive, holds alot, strong as hell, easy to get to (no fabbing fuel doors) check out www.transferflow.com just for kicks.
just my $.02
RN U OVR
Senator350 is offline
Old 11-22-2005, 01:08 AM   #20
DangerBoy
just my $.02
Thats the same thing I'm workin on doin.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline
Old 09-03-2004, 11:01 AM   #21
Joe67
67 is sold
Cool.
I have been thinking about the tank swap since I first read about the blazer tank swap a year or so ago here. I like having the tank under the bed, primarily to get it out of the way. I was never happy driving around with a 'bomb' behind my seat
Joe67 is offline
Old 09-03-2004, 12:57 PM   #22
nate68
transfer flow is based out of chico. i should see how much they would want to build me tank
nate68 is offline
Old 09-03-2004, 02:56 PM   #23
John Fabris
TOTY 2006
John Fabris's Avatar
"I was never happy driving around with a 'bomb' behind my seat "
I was just wondering why people say this? I have not heard or seen of any of the old trucks (of which most of them have tanks in cab) blow up or catch fire because of the in-cab tank....
Not trying to be an a$$, just wondering why those that do this swap are really doing it for? (I would expect most do it just because)
John Fabris
67 C10 SWB
John Fabris is offline
Old 09-03-2004, 03:46 PM   #24
Joe67
67 is sold
It was just a joke...
Personally, I'm doing it to clean up the side of the cab and remove the filler top and gain even a little seating room inside the cab. The room under the bed is wasted space, so I might as well take advantage of it
Joe67 is offline
Old 09-04-2004, 11:05 AM   #25
junkyardjohn
junkyardjohn's Avatar
"I was never happy driving around with a 'bomb' behind my seat "I was just wondering why people say this? I have not heard or seen of any of the old trucks (of which most of them have tanks in cab) blow up or catch fire because of the in-cab tank....Not trying to be an a$$, just wondering why those that do this swap are really doing it for? (I would expect most do it just because)
JOHN FABRIS-- IN 1977 I WAS HIT BROADSIDE AT AN INTERSECTION BY A DRUNK DRIVER (I WAS DOING 55 OR 60) CAUSING ME TO ROLL END OVER END IN MY 72 3/4 TON FORD. AFTER ROLLING ABOUT 80 YARDS, I STOPPED WITH THE TRUCK UPSIDE DOWN WITH MY HEAD PINNED TO THE GROUND. IT STOPPED IN A LITTLE DEPRESSION IN THE GROUND, & EVERYTHING WAS FROZEN(IT WAS DEC. 23rd IN MICHIGAN). THE BEHIND THE SEAT TANK WAS JUST FILLED. IT SPLIT, & ALL OF THE GAS DUMPED OUT OVER ME, & ALMOST DROWED ME IN GASOLINE, AS MY HEAD WAS PINNED TO THE GROUND. I WAS PINNED IN THE WRECKAGE FOR ABOUT 20 MINUTES, I HAD PLENTY OF TIME TO PONDER THE PLACEMENT OF SUCH A FUEL TANK. THE ONLY REASON IT DIDN'T CATCH FIRE WAS MY BATTERY WAS THROWN OUT DURING ONE OF THE ROLLS. LUCKY ME-- I GOT OUT OF IT WITH A BROKEN BACK, 14 BROKEN RIBS, A BROKEN COLLAR BONE & ABOUT 300 STITCHES ON MY MELLON. SO YA .... IT IS KINDA A SAFETY THING. I CONSIDER THESE TANKS A BIG BOMB BEHIND THE SEAT ALSO. THE REASON YOU DON'T HERE ABOUT ALOT OF THE PROBLEMS WITH THEM IS THAT MOST OF THE PEOPLE WHO EXPERIANCED PROBLEMS WITH THEM ARE DEAD. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline
