Old 09-11-2004, 08:24 PM   #1
griesel72
griesel72's Avatar
HELP, my truck is stuck in 4 wheel drive!!
i have a 69 1/2 ton chevy, 4 speed/rockwell that is stuck in 4 wheel drive, the shifter shifts to where 2 high should be, but the front drive shaft is turning, and it makes a funny, not quite in, sound. The truck has the stock original lock-outs, that are a little hard to turn, but still seem to function.
i have tried nothing, i figured i would ask here first
thanks guys, this one has me baffled.
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 09-11-2004, 10:08 PM   #2
71swb4x4
71swb4x4's Avatar
I am sure you tried this already, but drive in reverse for a few feet, usually that will pop it out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-11-2004, 11:04 PM   #3
griesel72
griesel72's Avatar
wish it was that easy
i hope my transfer case isn't jacked
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
Old 09-12-2004, 12:41 AM   #4
Bhull2
Will the t-case shift at all? Will it go into neutral or 4 low? Or is it just stuck in 4 hi all of the time, regardess of where you shift it?
Bhull2 is offline   Reply With Quote
Old 09-12-2004, 01:26 AM   #5
1969 GMC
1969 GMC's Avatar
Your shifter may be worn, which could cause it to do that. Look under your truck after you shift to see if the shift rails are moving as far in/out as they should.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-12-2004, 01:31 AM   #6
72k5
72k5's Avatar
Sounds like you might have a hub malfunctioning. One locked and one unlocked can make some funny sounds in the front diff (doesn't do the spider gears any good either).
Probably quickest way to figure this out is to throw a jack under the front axle and check to see if the hubs lock and unlock properly, plus you can see if the TC engages and disengages.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements.
72k5 is offline   Reply With Quote
Old 09-12-2004, 10:38 PM   #7
griesel72
griesel72's Avatar
thanks for the help guys, i believe that 72k5 had the solution, one of my lockouts has some major problems, and didn't unlock
Thanks again to all you guys
David
1969 K10 Custom 10
1997 Z71
2006 King Ranch
1980 Wife
