![]() my truck is a 72 shortwheelbase and the front end sets 2 inches lower on the drivers side front,,than the other side what would cause that?? ive changed the cois put new ones on..and its still the same..and the cab mounts are good too,,,what could it be? the shocks,maybe? when i measured the hieght of each shock,they were an inch different,,can you help o this,,,thanks |
king $h!t
has it ever been wreaked my was and it still to this day dosnt sit rightbut also my frame bent the tryed to make it straight again but they didnt do areal good job
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s |
![]() Join Date: Dec 1999
Is it with someone sitting in the truck when you measure?
![]() Join Date: Apr 2002
I've had one coil cut shorter than the other for four years and it doesn't bother me. I had a frame shop look at my truck and it's got a buckled frame. It could be fixed with "only" four or five hours of labor, but I'm a cheap skate. I'd rather find another sb frame, like that's gonna happen...
------------------ '69 Custom 10 SB '66 Mustang Sprint '77 Sportster
'69 Chev Cust/10 swb, 350/700R4, 5"/6" '70 Chev C10 swb, 67 front, 454/700r4, 4"/5" '73 Chev stepper, 350/3 spd '84 Chev K20 350/4 spd '91 GMC 1500 Suburban 4x4, 350/700R4 |
![]() Join Date: Apr 2000
Check the radiator core support bussings.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
check and make sure your lower a arm is not bent, and check the rear end and make sure both spring packs or coils are the same hight.....
