Old 04-13-2005, 12:00 PM   #1
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
"Z" the frame or section crossmember
I need some opinions and pros and cons on which way to go to get my truck to lay out on 20s. Its already bagged and I have some belltech spindles but havent gotten them on yet. Ive got a pretty good size tire on it now but will probably go smaller before too long. Which method is more costly and complicated? Thanks for any help, I need all of it I can get.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 04-13-2005, 01:38 PM   #2
DM310
Z'ing the frame is more work than doing the crossmember and taking 1.5" out of the crossmember should allow you to lay on 20's
DM310 is offline   Reply With Quote
Old 04-13-2005, 01:49 PM   #3
bagged69c10
Also, do you have to replace the control arms?
1965 c-10 long bed
1993 Sierra x-cab
Old 04-13-2005, 05:21 PM   #4
DM310
No you dont, for either way you go
Old 04-18-2005, 09:30 AM   #5
bagged69c10
no help
1965 c-10 long bed
1993 Sierra x-cab
Old 04-18-2005, 02:16 PM   #6
DM310
no help??????
Old 04-19-2005, 11:32 AM   #7
bigred66
bigred66's Avatar
I would like to here more feed back on this as well...
Atom (bigRed66)
1966- C10
1995- Wide Body Talon
1987- Dodge Raider (4 sale)
2000- 4-door Nissan Frontier
2003- Ford Focus (wife)
bigred66 is offline   Reply With Quote
Old 04-19-2005, 11:54 AM   #8
grnddwn
belly dragger
grnddwn's Avatar
No help??? Maybe I don't understand the question
grnddwn is offline   Reply With Quote
Old 04-19-2005, 01:40 PM   #9
bagged69c10
Should I section the crossmember or Z the frame?
1965 c-10 long bed
1993 Sierra x-cab
Old 04-19-2005, 03:11 PM   #10
grnddwn
belly dragger
grnddwn's Avatar
The crossmember will should cuase you less grief
Old 04-19-2005, 03:54 PM   #11
DM310
As I said before if you Z the frame, there will be more work involved then just doing the crossmember. Are you doing it yourself and how good are you fab skills?
Old 04-19-2005, 04:22 PM   #12
Faster_than_you
z-ing fram
what does one mean by "z-ing the frame" and "sectioning the crossmember"?
thanks,
chris
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 04-20-2005, 08:00 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Faster_than_you
what does one mean by "z-ing the frame" .....
Take a look at these pics. It should give you an idea of what the term means. The reason it is called Z'ing the frame is because when its done the frame will have a Z shape due to the cut and raising process...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-20-2005, 08:20 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
what does one mean by .... "sectioning the crossmember"?....
Sectioning or removing a section from your crossmember actually take a section out of the middle of the crossmember. This raises the crossmember, and at the same time lowers the truck. Here are some pics from Capt. Kaos website. Follow the link for more details- Thanks to Chris for the pics
Old 04-24-2005, 04:03 PM   #15
SkyBlue72'
I have nunchuck skills , will that be work.
SkyBlue72' is offline   Reply With Quote
Old 05-03-2005, 12:12 PM   #16
1low1967
1low1967's Avatar
I "z"ed my frame 3 1/4 ins and it lays flat out on 275/45/r20. I was pretty easy but I have the cab off. The front horns is just like a boby drop.
1low1967 is offline   Reply With Quote
Old 04-19-2005, 04:27 PM   #17
DM310
Z'ing the frame is cutting the frame and moving one of the halfs up anywhere from 1-4" then welding it back together. Sectioning the crossmember is removing a section out of the crossmember to move the whole front suspension up as a whole. If you do a search you will be able to see pics which could help you
Old 04-21-2005, 06:46 PM   #18
loweredd
www.loweredd.com
loweredd's Avatar
Z'ing the frame is a piece of cake. Dont be a woman, Z the frame. LOL. J/P
loweredd is offline   Reply With Quote
Old 04-21-2005, 07:39 PM   #19
grnddwn
belly dragger
grnddwn's Avatar
Do both!
Old 05-04-2005, 11:44 AM   #20
bagged81
Signals in the bumper.
bagged81's Avatar
Originally Posted by grnddwn
Do both!
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 04-22-2005, 01:13 PM   #21
bagged69c10
Am I gonna have to do both because I heard that you should only do a 1.5" section on the crossmember. Is that gonna make it lay frame on dubs? My fab skills are pretty good, Ive done all of the rest of the work myself and it turned out pretty good considering it was all done in my driveway. Thanks for all the info so far.
1965 c-10 long bed
1993 Sierra x-cab
Old 04-22-2005, 01:49 PM   #22
DM310
well measure the difference of how much the crossmember hangs lower than the frame. From what I remember 1.5" is enough for the frame to be lower.
Old 04-22-2005, 04:36 PM   #23
loweredd
www.loweredd.com
loweredd's Avatar
It's going to depend on what size tire you use, and if you are going to try to get it on the rocker.
Old 05-03-2005, 01:05 PM   #24
bagged69c10
I just put my new Belltech drop spindles on and the correct plates and cups on the front and its alot lower but the crossmember is still a good 2 inches from the ground. I figured that when I did that it would lay the crossmember on the ground. Its probably just my monster truck tires.
1965 c-10 long bed
1993 Sierra x-cab
Old 05-03-2005, 04:46 PM   #25
fastbagged68
fastbagged68's Avatar
Cut your bag mounts more! If you are using a plate.... ditch it. and cut up and run a smaller cup! that will get your crossmember down unless you are hitting on something else. What size tire you running?
fastbagged68 is offline   Reply With Quote
