09-20-2005, 09:37 PM | #1 |
Still Green but learning
HELP!! low RPMs at Idle after a battery swap.
I had a battery leaking on me. I have swapped it out for another and now when I crank up I Idle so low that it actually cut out on me once. This has never happened to me before. Its worth noting that I discovered the battery leaking when I was changing the Washer fluid Tank on my truck.
It is an 02 Yukon with a 5.3L V8 Any help appreciated
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
09-20-2005, 10:25 PM | #2 |
blood type; Retumbo
it basically has to go through a relearn process. hold the idle at about 1500 then slowly let it off until it runs by itself
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
09-20-2005, 10:27 PM | #3 |
yeah, pretty much a relearn process, the quick way i learned was to cycle it thru D and R every few seconds with the idle hovering around 800, and prolly after 3-4 tries it would learn enough to allow it to drive around the block, in which it would still learn while driving
09-20-2005, 10:31 PM | #4 |
whew.... thanks guys, I thought that was the case but after driving around the block and it stalled, I got nervous. I will go do that now.....
MODS, Im removing the redirects now.... thanks
11-22-2005, 08:20 PM | #5 |
Re: HELP!! low RPMs at Idle after a battery swap.
Would you have to do this procedure after installing a Hypertech tuning?
Thanks, Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
