Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-21-2005, 02:43 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Old Tools What is this ?
I recently came across a bunch of Old Tools. I dont know what the lone one is. Anybody Know ??
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-21-2005, 02:47 PM   #2
l1n1b1
67 Shortstep
Re: Old Tools What is this ?
It looks to be circa 1700's....Early wood drill....the opening on the top was for a board (similar to a 2x4) to be inserted through it so that you could apply pressure to it by leaning into it with your chest.....
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Adapt, Improvise, Overcome
l1n1b1 is offline   Reply With Quote
Old 12-21-2005, 02:51 PM   #3
That would be my guess is a drill....though I can't provide the learned information my predicessor did.
Old 12-21-2005, 02:52 PM   #4
Jebb1978
Jebb1978's Avatar
Yeah it's a really old drill. My friend has one he still uses, very cool!
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 12-21-2005, 03:37 PM   #5
screamin_c102
screamin_c102's Avatar
Egg Beater......
Seriously though,I find it interesting that the teeth dont go all the way around the drive gear. Seems to be designed for a back and forth motion not a full rotary motion like a drill.
screamin_c102 is offline   Reply With Quote
Old 12-21-2005, 04:13 PM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I can't say for sure,but it sure looks like a lot of work
Cool stuff to have though
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-21-2005, 05:32 PM   #7
Professor
If there are not 360 degrees of teeth on the main gear, indicating that the only use of the thing would be to make the shaft move in a back-and-forth rotation by a similar back-and-forth rotation of the crank handle, it almost looks like an old valve lapper. ... for lapping in valves into the cylinder head (or, in the case of a flat-head engine, into the engine block).
Professor is offline   Reply With Quote
Old 12-21-2005, 05:36 PM   #8
smirch9
Try here www.papaswrench.com Papa will be able to tell you, in fact he is a member here to!
1999 GMC 2500--Natural Gas Powered baby!
2007 Chevrolet Tahoe
Have you subscribed? Click here.
Order your site t-shirts and apparel here!
smirch9 is offline   Reply With Quote
Old 12-21-2005, 06:01 PM   #9
Opper77
Ob-Gyn Kenobi
Opper77's Avatar
It is indeed a drill. If you look closer, the flat section is recessed below the teeth, and there are 3 patches of teeth that look to be at 120 deg to eachother. It will go all the way around...after the last tooth passes on the top the first one on the other side is just coming into engagement. If you had to cut teeth with a file or whatever back in those days, would you not just cut only what you need and not all 360 deg?
Being smart is not necessarily being lazy.
'85 GMC Shortbox...
I used to have a firm handle on life....then it broke off.
Opper77 is offline   Reply With Quote
Old 12-21-2005, 06:06 PM   #10
Professor
Good point, Opper. Its the little swivel attachment of the working end that makes me think its a valve lapping tool.
Old 12-21-2005, 07:15 PM   #11
kwmech
That is the original cordless drill.
Old 12-21-2005, 07:17 PM   #12
screamin_c102
Cool
Old 12-21-2005, 07:20 PM   #13
1970 CST Short Wide
Senior Moment
The teeth are in sections so as to make the bit go back and forth as you turn the handle. There's a gear at each end of the teeth and it only hits one set of teeth at a time makeing it change direction. the lapping tool has my vote so far.
Thanks for all the input.
Pittsburg Ca
94565
Old 12-21-2005, 07:22 PM   #14
71swb4x4
71swb4x4's Avatar
It looks like a tool we used to use to make rope. Maybe we were using an old drill to make rope, I was only 8 or 9 years old at the time so I really can't be sure.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-21-2005, 08:00 PM   #15
FormerMember
That was my thought, a rope winder.
Older than internal combustion engines is my guess.
FormerMember is offline   Reply With Quote
Old 12-22-2005, 09:18 AM   #16
Shorty Cox
The consensus at my office is, IT IS A COTTER KEY REMOVER!!!!!!!!!!
Shorty Cox is offline   Reply With Quote
Old 12-23-2005, 11:25 AM   #17
71RestoRod
71RestoRod's Avatar
As others stated... It's a valve lapping tool. The teeth are set up to use the handle in any one of three positions but in a back and forth motion. It looks like it might be missing the piece that sits on the valve... Here are a couple ones similar to it:
http://cgi.ebay.com/Valve-Lapping-To...QQcmdZViewItem
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 12-23-2005, 01:31 PM   #18
jamis
F.A.S.T. president
jamis's Avatar
I think the guy who last did some daily driver body work for me uses these tools.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 12-23-2005, 02:06 PM   #19
tnblazerk5
User #12137
tnblazerk5's Avatar
tnblazerk5 is offline   Reply With Quote
Old 12-23-2005, 01:51 PM   #20
Liz
Catchy title goes here..
Liz's Avatar
1970 CST Short Wide papawswrench has a site dedicated to old tools also. Its a newer site that is growing, but there are some very helpful people over there also. http://papawswrench.com
i so missed smirchs post sorry for the double but its a good place to check out
Last edited by Liz; 12-23-2005 at 01:52 PM. Reason: overlooked smirchs post somehow..
Liz is offline   Reply With Quote
Old 12-23-2005, 02:01 PM   #21
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i saw the 3 stooges use it for mixing batter (knuck knuck knuck )
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 12-23-2005, 04:52 PM   #22
No3Fan4Ever
Running on empty
No3Fan4Ever's Avatar
Oh a wise guy, huh............bwop, bwop, bwop. honk, honk, honk, blip(two fingers right beyween the eyes
We have two rules here at the Rock.
Rule #1: No writing on the walls.
Rule#2: Obey all rules
70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi;
94 Bronco XLT 302, auto;worn out daily driver
No3Fan4Ever is offline   Reply With Quote
Old 12-24-2005, 10:29 AM   #23
papawswrench
Sorry guys - I missed this post !
That is most likely a valve lapping tool , missing an attachment . It would alternate direction and lap the valve seat .
There are some like it that were used as paint mixers in the old days also . Judging by the old carpenter tools in the picture , that would be my guess as to what it was used for by the owner . Definitely "old school " !
papawswrench is offline   Reply With Quote
Old 12-24-2005, 01:57 PM   #24
papawswrench
Here is one on Ebay---
Link--http://cgi.ebay.com/Vintage-Antique-...QQcmdZViewItem
Old 12-24-2005, 10:03 PM   #25
Blue Beard
Blue Beard's Avatar
Looks like something used for the valve lapping, or the seats.
But they had something similiar to this not only for rope winding but for the wire cables...
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
