Old 07-18-2002, 10:21 PM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
Wiring door speakers
I know some people don't like the idea of cutting holes in their doors, but I've already made up my mind so don't try to talk me out of it. My question is this: How did all you door speaker guys wire your speakers? I mean going from the door itself to the cab, where and how did you run your wires?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 07-18-2002, 10:33 PM   #2
Super Chevy
Super Chevy's Avatar
you could just use some coated wires and hand them across or they sell a thing that has a plate on the cab,and one on the door, with medal connecters,they connect when you shut the door, looks slick, seen it on TV,mabe someone will have more info on it...
Super Chevy is offline   Reply With Quote
Old 07-18-2002, 10:41 PM   #3
photoglg
photoglg's Avatar
My truck had speakers in the door. They drilled a hole in the door frame and one in the cab frame with enough slack for movement for when the door opens. I have since removed the speakers and covered the holes, but i did reuse the holes in door frame to run the wires for the remote enrty.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 07-18-2002, 10:54 PM   #4
racedvl
racedvl's Avatar
I went out the firewall, along the gutter, behind the fenders, and into the doors.
racedvl is offline   Reply With Quote
Old 07-19-2002, 01:17 AM   #5
Low69CST
I don't have door speakers, but I am running wires for remote entry. I've drilled a small hole in the upper part of the kick pannel. I put in a rubber grommet and dropping my wires into the kick pannel. Then I'm drilling a hole in the jam and a corresponding hole in the door and am using a rubber boot out of a honda CRV to connect the 2 holes. The CRV boot is smooth rubber and is very slim. Should be as least noticable. Plus having a full rubber boot should give maximum protection from wear.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
