Old 08-20-2002, 05:21 PM   #1
WB72
Before and After
WB72's Avatar
Stock Stall Speed
What would the stock stall speed be on a 350 / 350?
I am looking for an advanced torque converter, and the base it on ??? above stock speed.
Any info on Saturday night special from TCI?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 08-20-2002, 05:34 PM   #2
bigvinnie
bigvinnie's Avatar
saturday nite special is about 400 rpm above stock, which is roughly 15-1700 rpm... I ran one before I switched to a 700R4 and was very happy with it....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 08-21-2002, 10:50 AM   #3
WB72
Before and After
WB72's Avatar
So correct me if I'm wrong, stock speed would be 1100 - 1300 rpm?
66,000 miles.
Alberta, CANADA
Old 08-21-2002, 11:11 AM   #4
Frank_Zeller
Frank_Zeller's Avatar
Stock stall 1500 to 1700. This is foot on brake WOT. Also dependent on how much torque you have. Had a TCI Saturday night special and it came in around 2100 with hoped up 305.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 08-21-2002, 01:30 PM   #5
WB72
Before and After
WB72's Avatar
I'm lost, Why do you need foot on brakes and WOT?
I thought that the stall speed was actually when the fluid transfered and your vehicle starts to move. If you are just above idle, the truck starts to move Aprox 1000 rpm. I just don't understand 1500-1700rpm. Is that when the converter rotates at the same speed?
HELP!
66,000 miles.
Alberta, CANADA
