Old 12-25-2006, 12:12 AM   #1
424shee
camaro,s-10 rearend?
I just wanted to hear some info on putting one of these rearends in our trucks.where to buy trailing arm perches?are the s-10 rearends 5x5 bolt pattern ect.anything you guy's got.the reason I'm wanting to do this is to get more offset on my wheel.thanks
424shee is offline   Reply With Quote
Old 12-25-2006, 12:26 AM   #2
layedoutnoma
layedoutnoma's Avatar
Re: camaro,s-10 rearend?
s10's are 5x4.75, sam as camro, chevelles,etc... most s10 are just 7.5" rears thouh which aren't that strong.
Meticulous Fabrications
Milford Michigan
layedoutnoma is offline   Reply With Quote
Old 12-25-2006, 01:36 AM   #3
jimmydean
jimmydean's Avatar
You'd be better off with a '73+ rear end. They are only 10 bolt, but they are cheap and you can get one anywhere. If you want a disc rear, find a late model Caprice or Impala rear.
jimmydean is offline   Reply With Quote
Old 12-25-2006, 02:05 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
The S-10 4x4 blazers 2000 and newer had the option of 8.8" ring gear and limited slip... not to mention discs. They are however 5x4.75 bolt pattern as previously mentioned. The 4x4 rear is a bit narrower than the 2WD. Buy the perches from ECE.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-25-2006, 01:25 PM   #5
424shee
thanks guy's!
