This makes Two trucks in a row that I have had trouble with the drivers side rear brake dragging. Any one else??? Any suggestions would be Great!!! Thanks Sams 68
could be build-up of gunk in your wheel cylinder preventing the cup/plunger from returning after you apply the brakes. Could also be weak brake shoe return springs...
I'd replace the wheel cylinder and put in a new brake spring kit... might as well do both sides so they're both fresh, can't hurt... could also be improperly adjusted e-brake cable as well.... ------------------ '72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA http://www.ixpres.com/vlusardi/chevtrk.htm [This message has been edited by bigvinnie (edited April 24, 2002).]
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
1969 Custom 30 wrecker
Join the club!
My '69 definetly wears the driver side more than the other side and I used to have problems with it locking up after a nice ride. I have replaced parking brake cables, even replace the driver side twice. I put in new springs twice. I too am at a loss as to what's causing this. Last year I had to swap my brake shoes side to side to get some decent mileage out of them. I used to have a '69 4X4 Blazer that did the same thing. If you raise the tire off the ground, the brakes feel free. ???????????????????? ------------------ 63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle Parts for sale: http://www.angelfire.com/trek/mr409/items4sale.html
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
![]() Join Date: Mar 2001
check the little 'star' adjustment wheel,
if the teeth are worn, it will over adjust make the lines wear. the thing is at the bottom between the shoes. ------------------ 71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73 See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
![]() Join Date: Apr 2000
I think if the teeth on the star adjuster were worn that would cause the shoes to back off. I would say that eather they are over adjusted or you have groves in the backing plate where the shoes ride
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
