03-22-2002, 08:30 PM | #1 |
think I found a 383...
just ran across a 3970010 block..."350" it has an externially balenced harmonic balencer and flywheel it has camel hump 291 heads...performer intake..its on a stand and i believe it has a huge cam, by how far the valves compress...going to ask the guy if i can pull the heads, to check bore and stroke..guess i could pull the oil pan instead...oh yea..its 400 bucks..i figure the heads are worth that..let me know what u think.
thanks Jim ------------------ 67 lwb fleetside...first hotrod in 25 years...283..186 bowl ported heads..270h comp cam 600 1405...stealth intake..HEI..th350 with 2500 rpm stall..4:10 POSI god I love to go fast
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
03-22-2002, 08:38 PM | #2 |
pop the pan,& look for a balance large balance hole drilled in #1 rod journal........400 sb only (crank)....69 longhorn.
http://community.webshots.com/user/hotrodhorn |
03-22-2002, 09:39 PM | #3 |
its all about the +6 inches
Just go get the thing. THEN figure what you have. You know it's not a 307 or a 305, so go get it. You can't go wrong if you know the sum of the parts.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Need to pick up the one ton Longhorn with a PONTIAC 350/350soon. Thanks every one! Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
03-22-2002, 09:46 PM | #4 |
im gun shy after the boat anchor one...lol..the guy said i can pull the heads and oil pan no prob tomorrow...ofcourse i'll get it..if it aint all screwed up...had a nice shinny new paint job on it....that always scares me...lol
