Old 04-29-2007, 09:56 PM   #1
2WD_Blazin_79
2WD_Blazin_79's Avatar
Blazer tailgate window problem.
I have a 79 blazer, and i took the top off for the first time today. Well i when I put it back on, the back window won't roll up. It's a manual window, and the crank just spins freely. What do I do?
79 2wd 4spd blazer.. The ex Arizona "Border Patrol" Truck.
2WD_Blazin_79 is offline   Reply With Quote
Old 04-30-2007, 12:16 AM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Blazer tailgate window problem.
Turn the lock with the key. Thats the way you lock the rear of the blazer up. When locked the crank is disengauged from the regulator, so it just spins. This way with the window up the rear is essentially "locked" without needing any other locking mechanism.
I will say it was smart of you to lock it with the top off to keep anybody from rolling the window up on you and breaking it with the top off.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 04-30-2007, 11:54 AM   #3
2WD_Blazin_79
I'ts not locked. When I turn the lock with the key the whole tumbler just slides out. It's broke somewhere inside, and I need to get this window up.
Old 04-30-2007, 12:12 PM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
Thats a problem. To get access to the lock/crank the window has to be up. Your best bet is to open the tailgate and pull the access panel. You will need to take the window off of the regulator. There are two slides that the window connects to the regulator (one per side). They do have bolts attaching them. With the window all the way down you should be able to get to the bolts without too much problem. With the window loose, you can slide it up/out of the gate. You can take the glass all the way out or just leave it in the gate as it will stay put (just be careful not to tweak it or run into it with anything as it will shatter). I left mine in, but was really carefull around it when I rebuilt my gate regulator.
At that point you should be able to get to the screws that hold the crank assembly on and remove it.
Here's a drawing from the shop manual with an exploded view so you know what you are looking at.
Rob Z.
Old 04-30-2007, 12:50 PM   #5
2WD_Blazin_79
Thanks. I will give it a try.
Old 05-03-2007, 05:55 PM   #6
2WD_Blazin_79
I got the window up. Thanks Rob.
Old 05-03-2007, 07:12 PM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
Sweet. What broke or fell off?
Rob Z.
Old 05-04-2007, 12:02 AM   #8
2WD_Blazin_79
The cast handle broke inside, which sheared the prawl and bent the spring.
Old 05-04-2007, 01:03 PM   #9
Zoomad75
K5Camper
Zoomad75's Avatar
Well, thats pot metal for you. glad you were able to fix it.
Rob Z.
Old 05-07-2007, 12:25 PM   #10
Damien
Damien's Avatar
I bought a new pawl from GM, but was afraid the thing would brake again so I had my mom machine one from alluminum. Worked great until the regulator rusted off and the new handle came apart at the pivot.
Damien is offline   Reply With Quote
Old 05-09-2007, 10:33 PM   #11
2WD_Blazin_79
Now i have another question. I got the new parts, but since I diddn't take it all apart (it took itself apart), how does the whole assembly go back together (key lock, spring, prawl, etc)?
Old 05-10-2007, 12:47 AM   #12
Damien
Damien's Avatar
If you inlarge the exploded diagram above you can get a pretty good idea. Thats how I did mine. I started with nothing. The local Gm dealer can print the diagram or parts of it too.
I can still count my vehicles on two... wait three hands.
Old 04-06-2013, 11:07 AM   #13
rallybas
Hi. I have a similar issue. Purchased new lock cylinder, prawl, and spring. It's unclear from the diagram how the spring and pawl mate up to the clutch housing. Seems as though if I put it in the wrong way it could fall into a cavity.
rallybas is offline   Reply With Quote
