Old 05-01-2007, 05:50 PM   #1
dmsteele92831
1968 Chevy 1/2 ton towing capacity
I have a 68 c10 with a 350, and 4 speed tranny, what is the towing capacity on these? I'm not sure what gears it has, is there anyway to check?
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
dmsteele92831 is offline   Reply With Quote
Old 05-01-2007, 05:52 PM   #2
1969k10stepside
Re: 1968 Chevy 1/2 ton towing capacity
Pull the rear end cover and on the ring gear there is some numbers like 41:11,ect.
Compare those to the numbers below and you have your ratio
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37,9
1969k10stepside is offline   Reply With Quote
Old 05-01-2007, 05:59 PM   #3
dmsteele92831
gracias!
1968 c10 Chevy
2005 Infiniti G35
2006 Subaru WRX STi
Old 05-01-2007, 06:28 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll need that info to determine what your towing capacity is.
Old 05-01-2007, 09:28 PM   #5
cruiserman
Really? Seems like brakes and springs would determine towing capacity.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 05-01-2007, 09:31 PM   #6
1969k10stepside
Think of it this way,you may have the biggest brakes in the world and 1 ton springs but your truck and 3:08 gears wont tow a trailer up a steep hill.Need lower gears to tow.Atleast 3:73s IMO,maybe 4:10
Old 05-01-2007, 09:44 PM   #7
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I swiped these off the board a couple of months ago. Once you know your ratio, I'll tell you how much trailer you can haul. I know they are a little hard to read, but if you squint you can make it out
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
